Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > BobCad-Cam
BobCad-Cam Discuss all BobCad software here.
Old 10-25-2007, 08:58 AM
TZ250 is on a distinguished road
Questions
Please help me to draw a simple 1" radius dome (2" diameter hemisphere).
I have a drawing that I want to project onto the surface.
I have 2007 & V21. I've drawn this part in BobArt, but can't get a toolpath and G-Code.
Thanks in advance.
BTW, I searched before posting. But I couldn't find what I was looking for.
Rob in Ohio
Old 10-25-2007, 12:27 PM
More questions.
I've just now sent the toolpath from BobArt to V21. However, I didn't want to cut the radius, only the negative relief portion. How do I do that?
I'm starting with a hemisphere that was turned on a lathe.
TIA!
Rob in Ohio
Old 10-25-2007, 02:32 PM
The One is on a distinguished road
You will need to create a 2D profile for the area you wish to cut (in the CAD screen) and select it before generating the Toolpath in BobArt.
As you input the values for the Machine Embossed model operation, select the Machine to Boundary option. It will then confine your toolpath to the selected area.
Regards
CNC mill questions - thrust bearings, leadscrew mounting, general questions tonofsteel DIY-CNC Router Table Machines 8 02-03-2012 03:42 PM
Brass vs Aluminium Vs Steel, questions, questions and questions... alexccmeister General Metal Working Machines 25 08-15-2011 12:40 PM
Some questions about the X2 (CNC) The Blight Benchtop Machines 0 02-22-2007 01:10 PM
Some Questions Metalcraft Open Source CNC Machine Designs 1 09-03-2006 11:08 AM
Questions Jim Cooper AjaxCNC Control Products 3 04-13-2006 01:18 PM
