Results 1 to 2 of 2
Thread: 2D to 3D
    May 2006
    2D to 3D
    Guys,
    Please help me to make a drawing a solid. I've used extrude, but that won't work on this part because the edges are not vertical.
    Imagine a standard 5 point star. Raise the center up 1". Now connect everything to the center raised point.
    How did I make this solid?
    TIA!
    Rob in Ohio
    Jan 2006
    One way...
    I think this is what you're looking for. Also the documentation has the basics for these operations. Check out the file and see if it makes sense. There are 3 layers in the file (points, wireframe, solid). All you're doing is going from a simple wireframe to a solid and the Solids menu is where you need to look.
    Start with a 3d wireframe for the star. Then add surfaces to the wireframe by making triangular planes using Solids->Surface Creation->Planar Surface. Create the "base" with the same function. Just select the wire geometry and use the menu function. Then I used Solids->Stitching->Stitch Surfaces to Solids to make a single 3d object. That's it.
    One trick with an object like this is to make one set of adjacent sides, then copy/paste them using rotate around 360 degrees and 5 copies. Also, I'm using V20, so your menus may vary.
    Have fun,
    Steve
    Attached Files Attached Files
