Page 1 of 2 12 LastLast
Results 1 to 12 of 15
Thread: Why did it do this?
    Registered ajinjax's Avatar
    Sep 2007
    Why did it do this?
    Bobcam left this little step between these two parts.
    The surface should be the same all the way around.
    It's just between the parts the ends are fine.
    Anyone got ideas on why that step is there?
    Registered tjones's Avatar
    Oct 2005
    The only way anyone could tell would be to check the code. I have seen simular results caused by machine lag but it really looks like it is in the code.
    The cad file and code would most likely need to be checked for any ideal of why.
    Sep 2007
    Quote Originally Posted by tjones View Post
    I was just looking at the code and created surface from NC. The Z depths #'s are the same.
    Mar 2005
    ENGLAND
    Quote Originally Posted by ajinjax View Post
    Is it a stepper motor system; if it is could be lost steps?
    Was the machining done in one continuous run?
    Were the surfaces machined with the same cutter (tool change)?
    John
    Sep 2007
    Quote Originally Posted by Oldmanandhistoy View Post
    John
    Yes (But that step is in between every set, not just one.) ,yes, and yes.
    Mar 2005
    ENGLAND
    Only other thing I can think of is the roughing pass was to deep or cutter heights (roughing and/or finishing) not set correctly.
    Did the roughing cut pass thru the stepped area?
    John
  7. #7
    Aug 2003
    Can you post the file? I may be able to help determine the cause and solution.
    Regards
  8. #8
    May 2007
    Kind of looks like things are moving around as the machine heats up.
  9. #9
    Sep 2007
    Quote Originally Posted by The One View Post
    Regards
    Well, there's 459738 lines of code and it's a 11.5Meg file.
    I tried to isolate a small part of the code but it's still too long.
    I doubt it had anything to do w/ the matl left over from the roughing pass, it's just foam.
  10. #10
    Oct 2005
    If it is not the roughing pass cutting deeper than the finish pass and the Z depths are correct then it goes back to machine issues.
    Both of these would be the areas to look into. If the machine is lagging due to whatever reason then slowing it down may improve the problem. If it is a roughing issue then simply change the Z comp of the rougher or change the program to leave more stock for the finisher.
    In light material like this the roughers with helical flutes tend to draw the material up. This would explain why there is stack left only in those areas. Where there were deeper cuts the material would be pulled with more force and cause this problem.
    We are only assuming as well that you made both a roughing and finishing cut so without more info it is hard to surmise the correct answer. But if I were betting I would go with the cut drawing the foam up in the deep areas of cut and since these areas are between two raised portions the cut is going down then back up causing the foam not to be drawn up.
  11. #11
    Sep 2007
    Humm I didn't even think about that.
    Also, the tool was a 1/4" Ball nose, taking steps @ 0.020" going from left to right (looking at the picture) if that means anything.
    Step away from the coffee.......
  12. #12
    Jul 2003
    New Zealand
    To establish if the problem is your code. Zoom in on the toolpath on the CAD side of BCC and read the Z coords of the lines in the offending areas and see if the same or not.
