Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > BobCad-Cam
BobCad-Cam Discuss all BobCad software here.
Old 10-04-2007, 08:21 AM
ajinjax's Avatar
ajinjax is on a distinguished road
There's no Roughing/finishing option?!?!
What the heck?
I'm just getting into this software and I'm stupefied trying to figure out how to get Bobcam to create a roughing pass program and then a finishing pass program.
I see they have a 3d Offset tool. Which would be fine, if it worked.
When I try that I get random lines shooting out in all directions.
Anyone have suggestions on how to work around this?
My thinking is to trick the machine by telling it to use a larger tool when creating the program and actually use a smaller tool. Then write a "finishing" program with the correct size tool.
Would that work?
Old 10-04-2007, 10:33 AM
tjones's Avatar
tjones is on a distinguished road
Bobcad version would be helpfull.
If you have a sample file it might also help.
For 3D roughing and finishing that is the way I do it with tool diameter.
In 2007 there are settings for this so you do not have to lie.
Old 10-04-2007, 11:35 AM
ajinjax's Avatar
I'm using Version 21.5.3
Old 10-04-2007, 03:22 PM
tjones's Avatar
Then the only option for you is to lie about tthe cutter diameter when 3D milling. Also translating the part in Z to get just Z stock.
I am not sure about those crazy moves. Would have to see the file to find that. i used 21 for over a year and do not remember getting paths like that.
Old 10-05-2007, 06:25 AM
ajinjax's Avatar
I think I know why it is making those lines.
The program I created the solid model in, Vectorworks, can't seem to make a 3D fillet correctly.
On a .125 step I couldn't make a .125 fillet. In order for me to make the fillet I had to make the step .126. So there's a .001 face just above the fillet.
I think that's what is freaking Bobcam out when it tries to do the offset.
Old 10-05-2007, 07:16 AM
tjones's Avatar
Did you try to use Bobcad to create a fillet? It may allow it where your other does not. Hard to tell.
Also if you are using a .25 ball mill them you do not need to create the fillet as it will be there by the tool radius anyhow.
roughing/finishing technique fpworks Hard and High Speed Machining 14 10-14-2007 11:33 AM
Using Roughing EM on 6061 mrk CNC Tooling 8 05-31-2007 11:27 AM
Roughing Problems Crashmaster General Metalwork Discussion 7 05-09-2007 11:32 PM
Plunge roughing? RdHawg Hypermill 3 01-03-2007 05:42 PM
Roughing/Finishing??? trevorhinze BobCad-Cam 1 08-02-2005 05:14 AM
