Look for the attachments button when your posting a reply. There is a list of file formats and sizes in the attachments window.
Usually we use Zip's
Go to www.filzip.com to get free file zipping software.
Cheers!!!![]()
Trying to connect to holes of diff. radi. and offset. The offset is diff in all axis. I would like to connect them with a radius. I would like to send a file of it but not sure how to do it.
Cheers!!!![]()
Toby D.
"Imagination and Memory are but one thing, but for divers considerations have divers names"
Schwarzwald
www.refractotech.com
Thanks give me a bit.
Toby here it is hope it works for you. Not sure on doing .zip files
sorry for the late reply.
I will need a few minutes to work with your part. I'll get back to you soon.
You want these tapered right, with or without radii at both ends?
BTW: If you need any Design work please feel free to visit my website below.
www.axiscncprogramming.com
Cheers!!!!!!
Toby D.
Schwarzwald
Here is your Carb Spacer in BCC Cad and DWG Formats.
I took the Liberty of inserting 1/16 radii on the Ventry openings.
I hope you like it![]()
I divided the Arc Geometry into segments and created Line geometry down the sides. Then using the Cross Section in the Solids Menu to Form the Skins .
Stitched everything together created two Planar surfaces to make it water tight for the Booleans Subtraction.
Cheers!!!
Toby D.
Schwarzwald
Toby, that looks great. I visited your site looks good, whats your rates?
Ok, now if I wanted the ventri to be radii. all the way or the way you have done it whats one thing in the manual that I could look out that would help me or features that would help me do this that I might not be aware of? Thanks very much for your help and time.
Toby D.
Schwarzwald
Toby, can I put a radius on on the big dia. if it is a solid?
I don't remember if I sent the file drawing without the Radii. I'll take a look and see, but note that the reason for the 1/16 radii is because a 1/8 radius didn't fit.
If you mean to place Radii in the actual Ventry this would take some playin with BCC. Not exactly easy, but possible.
Cheers!!!
Toby D.
Schwarzwald
yes I want as big of a radii in the ventri from the smaller to the biggest. I have tried and cant seem to get it to work.
Toby D.
Schwarzwald
