Results 1 to 12 of 12
Thread: Changing part orientation/origin
    SVM
    SVM is offline
    Jan 2006
    Can you move the origin and orientation of a part?
    Example: I draw a 3D model in SolidWorks. Then open it in BCC v21 and pick a surface I want to do a 2D profile on. If this happens to be a surface in the X,Z orientation for instance, then I need to change it to be X,Y to produce the G-code. Can you do that in BCC v21? Or do I need to do it in SW first? And if so .. how??
    Also, if the model happens to have it's origin somewhere other than a corner, can I then move the origin, or somehow reference to another point? In other words, can I select my X0,Y0 point on the part, before creating the G-code, making it easier to locate the part on the machine.
    SVM
    Dec 2005
    Changing part orientation and location
    Highlight the part in BCC v21, then use Change. In the submenu you can translate and rotate the part.
    Bob Parks
    Moderator tobyaxis's Avatar
    Jan 2006
    Quote Originally Posted by SVM View Post
    SVM
    Why not set an Origin in Solidworks before Importing into BobCad?????
    This is easy to do in BobCAD though.
    Select Solid Model>Extract Geometry
    Unselect All
    Point Menu> at intersection or Center of circle> and place your point where you want the origin.
    Then Select All>Change Menu> Snap> No Copies> select the point you created then the X0Y0Z0 at the center of the drawing screen.
    Done
    Hope this helps
    Cheers!!!
    Toby D.
    "Imagination and Memory are but one thing, but for divers considerations have divers names"
    Schwarzwald
    www.refractotech.com
    Registered tjones's Avatar
    Oct 2005
    I draw my parts in Alibre and hardly ever do I have it origined where it will needs machined.
    Very easy to do in the rotate and the translate menus.
    SVM
    SVM is offline
    Jan 2006
    Thanks for the suggestions, all were helpful.
    Toby, If for instance the part is 3D, with machining required on several sides, then the origin on the SW part will not be in the right place for more than 1 operation at best. But that aside, how do you move the origin in SW??
    I could not make the "Point Menu> at intersection or Center of circle> " thing work. I ended up placing a point as close to an end of a line as I could, but could not make it automatically select the endpoint, circle center or other feature. Ideas?
    Bob, the rotate was what I needed for that, thanks.
    After having rotated and moved the 2D part, I could not figure out how to make the tool path. I had that working before the rotate, but not after.
    I will play some more with it tomorrow.
    Jul 2003
    New Zealand
    Steen
    You need to have the snap points enabled.
    File: Environment: Snap Points
    May 2006
    Thumbs up Set a new origin in Solid Works
    I have never worked in BobCad, but do firmly agree with setting your origin in SolidWorks. Not only does that let you export correctly, but then you can print out 3D views for setups and get measurements that match the numbers on the machine.
    The easiest way I have found to do it is, ALWAYs use the Assembly Mode in SW, even if it is only a single part. Once you have your assy or part, bring it into a new SW assy file, for each set up on the machine. Then you can align it to the three basic Datum Planes and best of all, if your machine setup is not exactly like you expected you just go into that file and adjust the References to the as is condition for the set up. You now have your new numbers for that exact set up (very useful if you have often have to re-machine holding fixtures.)
    Tom G
    Apr 2004
    Forest Lake, MN
    The easiest way I have found to move parts and origins in SW is to use the Move/Copy feature.
    Go to Insert, Features, Move/Copy and you can move or rotate the part to anywhere you want.
    Sean
    Jul 2005
    Usa
    changing origin
    There is a way in Solidworks where you can create part origin. Once you draw the part in SW go to drop down menu under Insert>Reference Geometry>Coordinate System or if you have it already as I do in my tool bar. Menu opens in feature tree and asks for origin position and next three asks direction reference for XYZ . Once you create your new Cordinate System and say OK you can rename it in the feature tree.
    When you save it as a file format (iges,step,parasolid,etc) under file>save as>their is an option tap-click that and the export options box comes up. At the bottom of box their is a drop down menu next to the words Output coordinate Sytem. Their you have a choice first saying default(which is the SW default) next you should see Coord System 1 or the new name you changed it to. Now except all so now when you import to your cam sytem it will have the orientation and part origin you want in that plane (XY,YZ,ZX). Hope that helps and that I understood you.
    good luck
    JC
    I use Surfcam and if I leave it as is from SW and bring it in it will be the frontview plane not the top.
    SVM
    SVM is offline
    Jan 2006
    OK, Played a little more yesterday and today. Trying to get some work done at the same time.
    Arthur, Snap points were enabled, so something else went wrong.
    Good to "see you" btw! Coming your way again beginning of October.
    I worked some with JC's suggestion of adding a new coordinate system and that works pretty good. Only negative is that it then has to be saved as an iges file instead of a regular SW file.
    Doing it this way, it would be fairly easy to save a number of different versions, all with different coordinate systems and origins to be used for machining different sides of the object. I think that will work well.
    Sean, I could not figure out how to do the move/copy you mentioned! I am running an old version lf SW, 2003, so maybe its not an option?
    Tom, I see your point with the assy files, but unfortunately BCC does not open SW assy files, so thats a no-go.
    Steen
    Jan 2006
    I have no idea how to do that in SW.
    I use BCC for everything including Solid Modeling. Usually when I get a file from someone it is way out in space as if it were one part of a huge assembly. I use the Translate options first, then the Rotate. Being that 99.9% of these parts require multiple operations sometimes it is best to copy the original and save as each different rotational position for each operation. It helps to simplify programming for complicated parts.
    Toby D.
    Schwarzwald
    Oct 2005
    SW should be able to export assembly files to either a step or iges format.
    As for the move it works the same as all the previous versions.
    Go to the cadcam trainer forum and sign up. You will get access to several V21 videos and you should see how it is done.
    www.cadcamtrainer.com/forums/index.php
    Otherwise the help files show you exactly how to do it!
    1. Changing Fanuc part counter increment?
      By gearsoup in forum Fanuc
      Last Post: 06-23-2007, 08:50 AM
    2. Point of origin.
      By MonkeyKong at d in forum Mastercam
      Last Post: 07-04-2006, 01:40 PM
    3. Machine home vs part origin question
      By yukonho in forum Mach Software (ArtSoft software)
      Last Post: 01-23-2006, 09:05 AM
    4. Move part origin
      By vertcnc in forum Solidworks
      Last Post: 11-06-2005, 03:15 PM
    5. Changing the orientation of jgro linear bearings
      By js530 in forum DIY CNC Router Table Machines
      Last Post: 07-22-2005, 05:37 PM
