Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > BobCad-Cam
BobCad-Cam Discuss all BobCad software here.
Old 06-28-2007, 05:12 AM
Prboz is on a distinguished road
Engraving, Tangentail arcs, and crop circles
Gday to all,
Here is my problem.
Bobcad 21 with Mach 3 post processor and Mach3
- Select a Text and place it on the board.
- Vectorize text.
- Other - Offset
Ok Here it is.
If I go directly to Other - Pocket - Setup Spiral it returns the tool path for the whole letter. ( Great)
Go Into Mach3 HMMMMM Crop Circles.
Ok So I go into Change - Reorganise - Clean up and Optimize
Then Change - Reorganise - Make Arcs Tangential
Then go to other - Pocket - Spiral and it returns the toolpath for about 1/8 of the letter, about 3-4 runs around the outside of the letter.
If I do the Reorganise - Clean up and optimize and Skip the Make Arcs Tangential, then do the pocket I get a full toolpath but in Mach3 Get Crop Circles.
I usually set the Make Arcs Tang .0005 and 5
Have played a bit but without success.
This is really starting to Annoy me ( Keeping it clean).
Prboz
Old 06-28-2007, 07:39 AM
The One is on a distinguished road
Try using .001 and 15 for your values in the Make Arcs Tangential dialog. It may prove helpful.
Also, how did you get the text profiles?
Regards
Old 06-28-2007, 05:05 PM
tobyaxis's Avatar
Moderator
tobyaxis is on a distinguished road
Read this thread and make your changes to the Driver settings as needed. Here is the Link to the BobCAD/CAM Forum.
http://216.117.147.20/bobcadsupport/...ead.php?t=2828
Cheers!!!!!
Toby D.
"Imagination and Memory are but one thing, but for divers considerations have divers names"
Schwarzwald
www.refractotech.com
Old 06-28-2007, 07:25 PM
HuFlungDung's Avatar
Moderator
Crop circles sounds like a mixup in G02 and G03 arc direction in your controller due to one inverted axis direction, or possibly an incorrect post setting (in Bobcad) for the arc center coordinates, ie., incremental versus absolute.
Old 06-28-2007, 08:06 PM
ger21's Avatar
Originally Posted by Prboz View Post
...........but in Mach3 Get Crop Circles.
Try changing your IJ mode in Mach3. In the General Config screen.
Crop Circles are... stevespo BobCad-Cam 67 10-22-2009 04:32 PM
Huge Arcs HELP ????? Biggermens Mach Software (ArtSoft software) 3 04-26-2007 08:50 AM
Huge Arcs Biggermens Mach Lathe 0 04-23-2007 10:49 AM
Points on arcs gguidi Autodesk Software (Autocad, Inventor etc) 2 07-25-2006 07:49 AM
Cutting circles and arcs Hack General Electronics Discussion 4 11-08-2004 03:12 PM
