My toolpath over this 4"x22"x1" cube primitive created in BOBCAD v19 (File attached) is always:
- Having a Z level of always 1/2 the selected tool diameter ABOVE the part, and:
- A Fillet around the edges where none was specified or desired
Now, in the version 21 that I am looking at, the toolpaths generated are as I expected: sharp 90 degrees over the edges, and flush with the top of the model. What am I failing to set in version 19? I don't want fillets or an offset over Z, nor did I ever tell Bobcad to do so!
In the attached file,
VIOLET is the NC GEOMETERY
LIME is the BOBCAD TOOLPATH
BLACK is the MODEL
Thanks in advance. I ran into this problem on day 46 of my 45 day support license.
Zenjon
musta done something bad in a past life!
LinkBack URL
About LinkBacks
