Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > BobCad-Cam
BobCad-Cam Discuss all BobCad software here.
Old 06-15-2007, 04:19 AM
shepherd is on a distinguished road
return height
hello. i am new to bobcad and machining in general. plz help.
this is probably going to be very vague, so bare with me. i uploaded a pic in bobart, then sent the contours to bobcad to engrave it. i then had bobcad created the nc for me. i assumed it would travel around the picture when i machine it, but it would rapid from one point to another at random with the tool in the part breaking the tool. i tried to edit the code with what knowledge i have, i got an alarm along the lines of can not interrupt the tool path (cant remember exactly). well i guess my question is is there a way to have bobcad when it rapids to move the tool out of the part?
hope this makes sense, thanks!
fanuc 6m on a excel.
Old 06-15-2007, 06:34 AM
Kiwi is on a distinguished road
Have you set the Rapid Plane Height?
On the Cam side: 'u...d...' button will bring up Tool Depth Settings window. Enter your height in the Rapid Plane Box.
Old 06-19-2007, 11:54 AM
i've just tried this, but it changes nothing in my gcode, so i can only assume it will rapid right into the part still. is there something special i have to do for the change to take affect?
Old 06-19-2007, 01:32 PM
tobyaxis's Avatar
Moderator
tobyaxis is on a distinguished road
Make sure you only have the entities you want selected before CAMMING. If you have a point or a line segment selected the software will see that and write the G-Code regardless. In other words an entity like a lead in plunge cut.
Toby D.
"Imagination and Memory are but one thing, but for divers considerations have divers names"
Schwarzwald
www.refractotech.com
Old 06-19-2007, 03:11 PM
The One is on a distinguished road
Also:
Do not use the Generate NC command. It does not obey all of the logic necessary to generate code properly. You can also do this:
Select the Geometry.
Click on Change => Reorganize => Cleanup and Optimize.
Then set your u..d..
Next click Machine Auto(your geometry should still be selected before clicking on this).
That should help a little.
Regards
Old 06-19-2007, 03:27 PM
msomerville is on a distinguished road
It sounds like your U/D settings are off.
Where is the face of your part in relation to Z0?
If you only had your clearance set to Z.1 but the face of your part is Z.5 then a crash would occur.
Old 06-19-2007, 11:20 PM
GeneK is on a distinguished road
I think I understand what you are saying. Did you just select all and then generate the code from that?
In BobCad you sometimes have to select one outline at a time, pay attention to the arrows, and generate the code in sections. If the outlines are not complete you may have to do some touch up to close some paths and make the cutting go where you like. I'm vague here because I'm being general about it. Normally I use the profile function to set up the different sections and then sent them to post.
GeneK
Old 06-20-2007, 12:08 PM
thank you every one, this helped greatly. i've just tried your suggestions and produced some code that looks like its going to work. i'm going to test it out tonight, i'm very excited. thanks again
How to fix Zero Return after crash burroughs Machine Problems, Solutions , Wireless DNC, serial port 2 03-10-2007 03:49 AM
Upc Battery & Zero Return Jedi General CNC (Mill and Lathe) Control Software (NC) 1 02-20-2007 08:44 AM
Torch Height Control / Capacitive Height Control ahlbebuck Open Source Controller Boards 0 11-27-2006 01:32 PM
Z return margin error Shotout Haas Mills 3 10-15-2006 10:05 AM
Fanuc 18M Z return pinguS Fanuc 12 07-26-2006 09:43 PM
