Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > BobCad-Cam
BobCad-Cam Discuss all BobCad software here.
Old 06-13-2007, 02:51 PM
Jim Estes is on a distinguished road
Spiral thread surface
I am wondering if anyone can help me out with creating this solid. In the attached file you will find a constant pitch tapered spiral and a profile of what the thread should look like. I tried using Sweep to create the surface but it created strange shapes.
www.maverickmoldandtool.com
Old 06-13-2007, 03:21 PM
The One is on a distinguished road
Which version are you using?
Regards
Old 06-13-2007, 05:00 PM
V21
Old 06-13-2007, 05:20 PM
tobyaxis's Avatar
Moderator
tobyaxis is on a distinguished road
You will have to Create the Thread by calculating the Major, Minor, and Pitch Diameters. This can be done with V21 because I have been doing it for a few months now.
Here is your file back. This isn't exactly what your looking for but it is an idea. I Created Joined lines at the top and bottom of the spirals then used Create Skin Surfaces in the Solids Menu.
To get what you want it will take some trial and error.
Cheers!!!!!!
Toby D.
"Imagination and Memory are but one thing, but for divers considerations have divers names"
Schwarzwald
www.refractotech.com
Old 06-14-2007, 07:21 AM
Thanks, tobyaxis. I was trying to use Sweep surface, but it wouldn't make them right.
Jim
Old 06-14-2007, 07:24 AM
Jim,
OK, this will be a slight issue. Version 21 does not handle the sweeping of a surface in a way that would produce the part you are after. In V21, the sweep surface function tries to maintain the normal of the Sweep Chain and not necessarily the Sweep Path. That is why the resulting thread twists and bends in areas that it shouldn't.
I know that this doesn't really answer your question, but 2007 has options in it that allow you to create the Thread with out the visualization in it. Also, there have been some modifications to the way the Sweep function is handled in 2007. Now you have an attachment point on the Sweep Chain, which is good to maintain the position of the Sweep Chain with the Sweep Path. There are also some updates to the surface and solid functions just around the corner (for 2007).
Regards
V18.0 Spiral Thread post has no "Z" Output twt BobCad-Cam 11 09-09-2011 08:58 PM
Making a spiral face thread Wiseco Haas Mills 3 06-06-2007 01:58 PM
Spiral saw RPM nophead00 General Metalwork Discussion 2 04-22-2007 03:43 AM
2D contouring with spiral Alan L Hypermill 0 12-30-2006 07:53 PM
The magical spiral paul3112 G-Code Programing 3 08-06-2006 09:46 AM
