Results 1 to 7 of 7
Thread: Finish Cut How too ???
    Aug 2004
    I am playing with bob cad v21 and trying to program a ruffing cut and then a finish cut for my lathe i no how to make a ruffing cut and a finish cut
    but i dont no how to do bolth of them in the same program ????
    THanks
    Moderator tobyaxis's Avatar
    Jan 2006
    Quote Originally Posted by Biggermens View Post
    THanks
    Can you Copy and Paste your program here on the Forum? It will help in seeing what you want to do.
    What Machine Tool and Control are you using, Fanuc?
    Toby D.
    "Imagination and Memory are but one thing, but for divers considerations have divers names"
    Schwarzwald
    www.refractotech.com
    Registered tjones's Avatar
    Oct 2005
    Watching Sorin's video may help.
    Aug 2004
    tobyaxis
    do you want the bobcad file or the gcode program ???
    Jan 2006
    tobyaxis
    Which ever is easiest for you.
    Toby D.
    Schwarzwald
    Aug 2004
    I put the to the gcode and the cad file from bobcad i had to put .dxf so i can up load it just delete the .dxf at the end of the file
    in the cad file i did a 0.050 ruffing cut then i moved the tool path up 0.030
    and i used the drawing as the finish cut it dont work that good but it works
    and i dont think it is the right way to do it
    Attached Files Attached Files
    Jan 2006
    First thing first, on a Lathe all your X Coordinates should be Positive unless your machine is set up to machine in X-(minus).
    Second, what is the Largest Diameter supposed to be?
    Third, what Canned Cycles does this Control Support? G70-G76
    Forth, this is not your average run off the Lathe part LOL, so what type of Tool Holders do you have, CNMG's, DNMG's, and a VNMG Profiling Tool?
    This is need to know information for this type of part.
    Toby D.
    Schwarzwald
    1. How to finish aluminum?
      By jason_n in forum DIY CNC Router Table Machines
      Last Post: 03-29-2007, 12:04 PM
    2. Bad finish
      By fadalman in forum Fadal
      Last Post: 12-09-2006, 02:00 PM
    3. Finish path
      By tt_raptor_90 in forum Mastercam
      Last Post: 07-05-2006, 10:28 AM
    4. 32 surface finish
      By mroy0404 in forum General Metalwork Discussion
      Last Post: 05-28-2006, 10:02 PM
    5. Help with Micro finish
      By Tulak in forum Haas Mills
      Last Post: 11-07-2005, 08:07 PM
