Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > BobCad-Cam
BobCad-Cam Discuss all BobCad software here.
Old 04-23-2007, 07:28 PM
BallisticFab is on a distinguished road
Restore File
Does anyone know where Bbobcad stores it's temp drawings for the 'restore file' function on load up? I remember Sorrin from the training classes brought it up once but I don't remember much on how. Thanks -Jeff
Old 04-23-2007, 08:27 PM
HuFlungDung's Avatar
Moderator
In Win9x, older versions of Bobcad used to store directly into Windows/Temp.
In the more modern version of windows, it will likely be worth checking in your own temp folder, found under Documents and Settings/your username/local settings/temp.
BTW, you won't see this folder unless you have hidden files and folders set to show up in your advanced settings found under Folder options/view in windows explorer.
CAD file to CNC sc351cobra General CAM Discussion 0 12-18-2006 03:07 PM
Need help with a dwg file Kuhlmann75 General CAM Discussion 8 10-10-2006 08:11 PM
php file larry53 Forum Questions or Problems 1 09-14-2005 10:26 AM
.PSC file? boomer187um Autodesk Software (Autocad, Inventor etc) 0 08-29-2005 10:15 PM
Anyone want to help me with a file? nervis1 Mastercam 19 05-12-2005 05:06 PM
