Need Help! remove unwanted points
Results 1 to 2 of 2
Thread: remove unwanted points
    Registered hmoore01's Avatar
    Sep 2011
    Default remove unwanted points
    Please forgive me for asking what should be a simple answer.
    I am trying to learn V25, with some luck.
    After searching for hours ,with no luck I must ask.....
    How do you delete unwanted points from a drawing.
    Harry
    Apr 2009
    Default Re: remove unwanted points
    If there are a lot of points and want to delete all of them, use masking
    If you want to delete all of them,when you create them use a different color,then you can select by color and trash can them all at once
    you can also put all points on their own Layer,,then only activate that layer and hit "ALL",then trash can them
    you can also just highlight them one by one and throw them in the trash can Icon
    you can also use the quick trim feature
