Need Help! BobARt emboss Z heights
Results 1 to 16 of 16
Thread: BobARt emboss Z heights
    Aug 2005
    Default BobARt emboss Z heights
    Two things. How does Bobart interpret colors to Z height. If I say emboss .1" then Black is .1 and white is 0" or is it something else. I would like to control the depth little better by changing colors with photoshop.
    2nd, BA places the bottom of image at Z zero. I tried to translate it down but image is not selectable. How can I manipulate the image
    Member aldepoalo's Avatar
    Mar 2012
    Default Re: BobARt emboss Z heights
    This video should help.
    Al DePoalo
    Partner Product Manager BobCAD CAM, Inc. 866-408-3226 X147
    Aug 2005
    Thanks Al, but maybe I missed something. I’m working with raster image and all the same color, I need to recess an certain area. The only way I know is to change the colors in photoshop. Of course I have to learn how to do that.
    Rob
    Ghost BurrMan's Avatar
    Dec 2008
    Quote Originally Posted by artracing View Post
    Rob
    Should be greyscale gradient artracing.
    Not super familier with photoshop, but it should be something like convert image to greyscale, then use a lighten and darken brush to manipulate hieghts.
    Aug 2005
    Quote Originally Posted by BurrMan View Post
    Yes, your right. I'm in the process of figuring that out. I need to change the darkness of that area without altering the texture. More education. I changed the darkness but it altered the texture but that does work. Just need to back pedal and not change surface texure.
    Rob
    Dec 2008
    And on the second question, you can use the bobart stock edit to set the entire emboss down in z....
    Some of the emboss dialogues have a "base hieght" setting also for that.
  7. #7
    Aug 2005
    I ended up changing the surface color in photoshop and it gave me the depth I needed.
    .I wonder is I set boss depth to 1 inch for black and use 90 percent opaque black would the depth be point .9 inches?
  8. #8
    Dec 2008
    No, i dont think so. I think it will be the "1" you set, and everything gradients down from that.....so, the highest point ("pixel") will be 1 inch.....
  9. #9
    Aug 2005
    I think I said that wrong. If I set depth to 1 inch, black will be one inch deep.
    If I add another color that is 90% Black. will that go to .9 inch’s and continue the gradient to white will I see the tool ramp to zero?
    Working in gray scale with raster image it seems to be working this way.
    I never educated myself in pixel/byte, values on how it all works in the digital world.
  10. #10
    Dec 2008
    Yes, thats mostly how it works... the darkest pixel will be the 1 inch, whether pure black, or whatever it is..
    But pretty sure the "levels" are a 255 grey scale. So doing a "90 %" wont get you to exacting depths like you are describing.
    You will want to look at 255 as "a whole" then do your division and set a color value with the number...
  11. #11
    Dec 2008
    So a test would be to use the "90% mod" on your color, then use the color picker to check the new color value, and see how close to 90% of the original color you got.
    When usimg the global type modifiers, 90% can be something different, because there are other parameters to the particular tools that can make "90% of a tool that mods at 45%" kind of situation.....
  12. #12
    Aug 2005
    I’ll have to do some experiments. Would be handy if it was that easy.
    Set the the most down level to pure black and percentage for all others.
    Photoshop uses percentage opaque. So 90% should equal 230 at the bytel level if that’s how it works.
  13. #13
    Member Gallchobhair's Avatar
    Jun 2012
    Here is a grey scale I use in Bobart to make heraldric items and here is what Bobart gives me. I set the material to 24X24x1. I make them large as I save as stl and use them in other programs.These are not the same but should give you an Idea what Bobart can do
    Attached Thumbnails Attached Thumbnails BobARt emboss Z heights-template-003-jpg   BobARt emboss Z heights-final-jpg
    The time has come the woodworker said to speak of many things. 0f routers and Wood , chips and paints and stains and CNC and other things.
  14. #14
    Dec 2008
    Quote Originally Posted by Gallchobhair View Post
    That's righteous!
  15. #15
    Apr 2009
    Nice work Don
  16. #16
    Jun 2012
    Thank you for the kind words. I would suggest to the OP go to youtube and look at all the videos on Bobart.
    I learned from those videos. there are quite a few.
