Problem Machining a STP file in Bobcad Ver30 build 2553. Not happening? - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 28 of 28
Thread: Machining a STP file in Bobcad Ver30 build 2553. Not happening?
  1. #21
    Registered JohnHennessy's Avatar
    Aug 2015
    Default Re: Machining a STP file in Bobcad Ver30 build 2553. Not happening?
    thanks I'm looking for a little more detail. I am coming along fine with the stl I have a;ready...I can buy one in an stp format but the detail is not there. I've been building bikes sense 1978, This is going on the bike representing my shop. now that I have the time and resources, I'm going to build a working file with as much detail as possible... Thanks again....
    The end result is directly connected to the effort applied
  2. #22
    Aug 2015
    Default Re: Machining a STl file in Bobcad Ver30 build 2553. Not happening?
    Quote Originally Posted by magicniner View Post
    Freecad can be used to convert .stl to a solid by importing the .stl in the mesh workspace then in the part workspace create shape from mesh then saving out in the format of your choice,
    - Nick
    That's what I'm looking for damn right, does the free in freecad actually mean its free?
  3. #23
    Apr 2009
    ok,,I guess your direction now is FreeCad ?
    I also am thinking or assuming that you are using 4th axis ?
    If that is correct,I am out,,,Nick and Burr would be better to help you
  4. #24
    Feb 2013
    United Kingdom
    Quote Originally Posted by JohnHennessy View Post
    Yes, it's completely free, I only use it as a tool for converting .stl meshes into solids I can use in BobCAD.
    I quite like targeted ads if they're not intensely annoying so I'll enable ads when your advertisers stop using annoying sounds, annoying slideshows and annoying animations
  5. #25
    May 2013
    Good to know
    A while back was there some conversation about the mesh having to be water tight if so does it do a good job at that?
  6. #26
    Feb 2013
    United Kingdom
    Quote Originally Posted by RAF. View Post
    Good to know
    I don't create meshes in FreeCad, I use BobCAD V25 plus an old, free version of Netfabb (from before Autodesk bought the product and which can still be found on GitHub) to clean up any problem areas.
  7. #27
    Aug 2015
    I'm posting this in hopes someone with the same problem can over come it by using my labor so you wont have to...... The answer to my problem was to use "emboise from component" in bobart .....
  8. #28
    Apr 2009
    Cool,,,,love to see the finished product
