Need Help! Advise on advanced Z level finish
Results 1 to 3 of 3
Thread: Advise on advanced Z level finish
    Member Bazzer's Avatar
    Apr 2016
    United Kingdom
    Default Advise on advanced Z level finish
    I am hoping some of the experts on this forum could cast their eyes over the screen shot of an Advanced Z level finish adaptive tool path and answer a question that I have.
    In the attached screen shot you will see redlining around an area where the programme is starting to change the tool path stepdowns as the geometry changes, there seems to be 3 distinct types of step down/over, is there any way to make this change a gradual one rather than in two steps?
    This is programmed in V30 3 axis pro, the cutter is a 6mm ballnose.
    Barrie
    Attached Thumbnails Attached Thumbnails Advise on advanced Z level finish-advanced-z-level-finishing-jpg   Advise on advanced Z level finish-finished-item-jpg
    Attached Files Attached Files
    Barrie @ Composite Specialities Ltd. using BobCAD V30 Mill 3 axis Pro, Bricscad V14 and MOI V3 with CNC-Step High Z 1000S and Wabeco CC-F1210
    Member The Engine Guy's Avatar
    Jun 2008
    UK
    Default Re: Advise on advanced Z level finish
    Yes. it does look to be a pretty poor toolpath, I haven`t used any Z level toolpaths for a long time since the Pro version of BC has "Advanced Rough" and I also prefer "Planar" or Advanced Planar" for finishes, just a thought, have you tried using the above mentioned Strategy at all ??
    Regards
    Rob
    Apr 2016
    United Kingdom
    Hello Rob
    No I have not tried any of those tool paths, I will give them a go.
    The finished part has a rougher finish than you would expect, mostly because the machine was being run at 'warp speed 9' to get the job completed in a free slot.
    That does not get away from the fact that I am sure Bobcad can produce some more elegant tool paths, but it is case of knowing what to do and unlocking the potential.
    Experience!!
    Regards
    Barrie
