Need Help! M99 Loop Issue
Results 1 to 3 of 3
Thread: M99 Loop Issue
    Nov 2015
    Default M99 Loop Issue
    I am programming a Haas SL10 with Bobcad v28. At the end of the program the program loops and restarts as it should. The problem is it advances to the italic bold line and stops...
    Spindle continues to turn but no tool movement. BTW this program and others written with Bobcad work fine when run with an (M30 or manually). Any suggestions will be greatly appreciated.
    N1 (DATE - 11-06-2017, TIME - 11:51 AM)
    N2 (POST -HAAS LATHE);
    (TOOL #1 80 DEG. 1/64 ROUGH TURNING);
    (TOOL #2 80 DEG 1/64 FINISH TURNING);
    (TOOL #3 .03 GROOVING TOOL);
    (TOOL #11 1/8 WIDE CUTOFF TOOL);
    (TOOL #12 PART PULLER);
    N3 G20;
    N4 T101;
    N5 G54;
    N6 G50 S1500;
    N7 G97 S1000 M03;
    N8 M08;
    N9 G00 X.07;
    N10 Z0.;
    N11 X0.466;
    N12 G01 Z-1.376 F.004;
    N13 X.506;
    N14 Z-1.516;
    Member CS900's Avatar
    Aug 2006
    Default Re: M99 Loop Issue
    maybe a silly question but is the lathe going back to IPM mode (G98) when it exits the sub program?
    Nov 2015
    No it's not... another thing that makes no sense (to me) is that when run on the graphics screen the program will run in a loop (M99).
M99 Loop Issue
M99 Loop Issue
