Need Help! Bobcad not posting Helical Interpolation Correctly
Results 1 to 5 of 5
Thread: Bobcad not posting Helical Interpolation Correctly
    Nov 2017
    Default Bobcad not posting Helical Interpolation Correctly
    Im trying to do a circular interpolation using BOBCAD v30 and im running a Fanuc 21m control. Im using the fanuc 21m post processor and when i post it there is no Z movement in the interpolation line (G03) so the machine just hovers above the part doing circles. If i add a Z movement, either with a different post processor or manually, the machine errors out as soon as it sees the Z movement and says "illegal plane movement commanded." Any tips?
    Member The Engine Guy's Avatar
    Jun 2008
    UK
    Default Re: Bobcad not posting Helical Interpolation Correctly
    If my memory is serving me right then I think that Helical Interpolation is an Option on your control, that will mean that the Parameter to enable it will be one of the 9000 Parameters, I think it is Parameter 9930 Bit 3 that needs to be changed, usually costs money for Fanuc to do it
    That would look something like 9930 00001000. Parameters count from the right and begin with 0 not 1 so Bit 8 from the right is actually numbered 7, hope that helps
    Sorry, that`s all I`ve got
    P.S. Just found this, have a look here for yourself
    https://www.scribd.com/doc/273845264...Parameter-9900
    Regards
    Rob
    Member aldepoalo's Avatar
    Mar 2012
    DeWalt MFG, it should be a simple fix to your post. Not all machines support helical motion which is why it's not defaulted on.
    This video should help you understand how to edit a post.
    What you are looking to do it edit the post format for arc moves.
    The 64 block should look like this:
    64. Arc move XY
    n,g_arc_plane,g_arc_move,x_f,y_f,z_f,arc_center,fe ed_rate
    This format gives you this g-code:
    N10 G17 G03 X-1.735 Y0. Z-0.05 R1.735
    N11 G03 X1.735 Y0. Z-0.1 R1.735
    N12 G03 X-1.735 Y0. Z-0.15 R1.735
    N13 G03 X1.735 Y0. Z-0.2 R1.735
    N14 G03 X-1.735 Y0. Z-0.25 R1.735
    N15 G03 X1.735 Y0. Z-0.3 R1.735
    N16 G03 X-1.735 Y0. Z-0.35 R1.735
    N17 G03 X1.735 Y0. Z-0.4 R1.735
    N18 G03 X-1.735 Y0. Z-0.45 R1.735
    N19 G03 X1.735 Y0. Z-0.5 R1.735
    N20 G03 X-1.735 Y0. R1.735 F89.2592
    N21 G03 X1.735 Y0. R1.735
    Al DePoalo
    Partner Product Manager BobCAD CAM, Inc. 866-408-3226 X147
    Nov 2017
    Thanks fellas! Sorry it took so long to reply. I dont think the machine supports it, like Rob mentioned. I was able to contact Bobcad and have the post processor modified to add the Z movement, but i get the same "illegal plane" error. More confused as to why my Grandfather(boss) assured me the machine supported helical interpolation. Guess its time to push for an upgrade.
    Thanks!
    Joshua
    Jun 2008
    UK
    Did you check the Parameters to see if it is enabled ??
    Regards
    Rob
