Need Help! bobcad v21 post needed
Results 1 to 6 of 6
Thread: bobcad v21 post needed
    Nov 2017
    Ireland
    Smile bobcad v21 post needed
    Hi im new to the site im looking for a c tek post for bobcad v21 if anyone could help it would be great , cant seem to find one online anywhere
    cheers tg12
    Member The Engine Guy's Avatar
    Jun 2008
    UK
    Default Re: bobcad v21 post needed
    Hi, I did have a CD that came with the software that had several hundred V21 PP on it, if I can find it I will have a look and let you know
    Regards
    Rob
    Nov 2017
    Ireland
    Quote Originally Posted by The Engine Guy View Post
    Regards
    Rob
    Hi rob
    Thanks for that any help would be great
    Cheers Tommy
    Jun 2008
    UK
    Hi Tommy
    Well, I have found the CD with the V21 Post Processors and had a good look through it but I can`t find anything that resembles a "c tek" control or machine of that name, got any more info on the machine and control that might help narrow the search ??
    If it is a fairly new or Chinese machine then it`s possible there won`t be one as this CD with the posts dates back to 2006
    Let me know if you have any more info.
    Regards
    Rob
    Nov 2017
    Ireland
    Hi rob
    The mill has a ctek controller also has CNT 806 A
    On it too
    I am currently programming on the controller but use Bobcad v21 on my other mill but unfortunately can’t find my posts disk anywhere
    The ctek controlled machine is 15 year old or older
    So I thought that there would definitely be a post available for it
    You can let me know if maybe the CNT 806 a is on the disk
    Thanks for looking
    Cheers
    Tommy
    Hi Tommy
    Regards
    Rob
    Member aldepoalo's Avatar
    Mar 2012
    The V21 post is faunc style for line and arc moves. Other than that you build in headers footers and tool calls using the macro menu...
    Why not edit a post yourself and get up and running on this machine?
    Al DePoalo
    Partner Product Manager BobCAD CAM, Inc. 866-408-3226 X147
