Problem Cutting unwanted areas not shown in code or simulation
Results 1 to 17 of 17
Thread: Cutting unwanted areas not shown in code or simulation
    Dec 2009
    Default Cutting unwanted areas not shown in code or simulation
    I'm having issues where bobcad will go severely off path and gouge the part breaking the tool and ruining the part. However there is no evidence of this in the simulation or code. I've tried various posts aswell.
    I've had the same issue with v28 v29 v6. It is always during an adaptive rough operation. I run other programs from fusion 360, pro-e, gibbs and others all without issue.
    Thanks for reading
    Feb 2013
    United Kingdom
    Default Re: Cutting unwanted areas not shown in code or simulation
    I quite like targeted ads if they're not intensely annoying so I'll enable ads when your advertisers stop using annoying sounds, annoying slideshows and annoying animations
    Apr 2009
    Dog legs.
    What machine are you running ?
    Do you have the advanced Preditor Editor ?
    Dec 2009
    It happens during cutting feed not during rapid but is dog leg in shape.
    Dec 2009
    It's a fadal.
    Apr 2009
    Without a .bbcd file to look at ????
    The reason I ask about the Advanced Preditor Editor is there is a way for it to show Dog Legs.
    Saved my butt many of times
  7. #7
    May 2013
    wonder if the new backplot in v30 would pick up the error
  8. #8
    Apr 2009
    I would imagine only if it had a radio button or the ability to access it's reverse post
    Don't want dog legs showing up,when your machine doesn't do them.
    In Preditor you have the ability to access the reverse post and turn them on
  9. #9
    Dec 2009
    I don't have predator software. attached is the Gcode for the part. if someone would be willing to check it out for me I would really appreciate it. I have all the recommended link settings in Bobcad applied that should make dogleg a non issue. also it is during the middle of an intermediate step in advanced rough.
    Attached Files Attached Files
  10. #10
    Apr 2009
    As you can see from this screenshot of what Preditor did,I am looking for a needle in a haystack.
    It would be most beneficial to be able to set-up stock and look at your .bbcd file
    If you are concerned about posting a .bbcd file on here,I understand
    You can PM me and we can do a different route
    I guess the only insurance I can give you that I will keep your stuff confidential is I been on here for 8 years
    that
    or
    Make another file that replicates your problem that is not a concern for confidentiality sakes
    Really need the .bbcd file and a copy of your PP
    Attached Thumbnails Attached Thumbnails Cutting unwanted areas not shown in code or simulation-needle-jpg
  11. #11
    Apr 2009
    natin,,private messaging is giving me headaches,,please e-mail me
    jrmach@yahoo.com
  12. #12
    Dec 2009
    Found the problem with the help from jrmach. Arc fitting was causing the issue. Something was wrong with the ijk lines in the code deep in the program. Unchecked arc fitting and reposted the program and problem went away.
    Not sure why the issue did not present itself earlier in the code with many ijk lines ran prior without problem?
    THANK YOU! Jrmach and everyone for your help.
  13. #13
    Apr 2009
    Glad that fixed it.
  14. #14
    Apr 2009
    This happened to me about 2 months ago with 3D adaptive rough
    Did not show up in simulation or Preditor
    SCRAP
    So I re-ran part(the scrap part) and found the line where it was bad
    It was an I and J,,it was not a rapid issue,,was in the middle of a cutting pass
    So I experimented a little with settings(on SCRAP) part
    I found 2 ways to conquer the problem
    1 Turn of Arc Fit (which makes a ton more unwanted code,unwanted computation and posting time)
    or
    2 make no intermediate cuts (which also defeats one of the cool thing about this tool path)
    That said,
    Way back in V23 days I had 2 different engraving tool paths go south on I,J,K lines
    On that there is no "arc fit " if I recall right
    Two choices there
    1 go into PP and turn off I,J,K
    2 find exactly where things go south by re-running (SCRAP) part,,then change the geometry at that point ever so slightly and re-compute
    On engraving changing geometry on those particular things you could never notice
    But
    In all those cases simulation and preditor did not detect or better said,did not show what the code told the machine to do
    However,my machine simulation did,however,my machine is almost 20 years old and it only shows in backplot mode and the screenshot is very small.You really could not tell very easy,barely,barely noticeable
    So for whatever reason,,I suspect a mathematical reason,I,J,K will spit out bad once in a blue moon
    Natin,you said that BOB had been looking into your problem and could not figure it out
    I hope you follow up with them and supply them with the information with where exactly the I,J,K was computed wrong
    There is always a reason for everything,hopefully they can figure out why ?
  15. #15
    Apr 2009
    Just to mention,,,I run a Haas and the OP a Fadal
    I have had this problem in multiple versions and so has he
    I don't believe this a PP thing
    Thinking a behind the scenes calculation that we have no control of
    Only happens when the moon is in the seventh house and Jupiter aligns with Mars kind of problem
    but
    it is SCRAP when it does
  16. #16
    Dec 2009
    In my experience I had this happen on just about every program I tried. rendering the software unusable. Been programming with fusion in the meanwhile with zero issues using arc fitting or anything for that matter.
    The only reason I kept trying bobcad was because I actually enjoy the software compared to nearly all others I've demoed.
    I have told BOB what the problem was and the exact line. But for now leaving arc fit off is an easy fix.
  17. #17
    Apr 2009
    natin,,
    very rare for me
    but then again you said you were running a 1/2 dozen intermediate cuts,,maybe there is something up there also ?
    If you can give a complete file (.bbcd) in V29 or lower of a part that has also done this,,chances are the forum may be able to narrow this down
    leaving arc fit off may be easy fix,,but that is not fixed..Those long programs like you just had,,takes a lot of patience computing and posting and loading in the machine by not using arc fit
