Need Help! Modifying Post
Results 1 to 4 of 4
Thread: Modifying Post
    Jan 2005
    Default Modifying Post
    I am trying to add some line of codes into my post. I had done this previously, but had a hard drive crash and didn't have the modified post backed up.
    Basically I want a window to pop up so the operator can check the Z-shift ( which is the material thickness plus the wasteboard thickness) and manually enter the value before proceeding. I have got the window to pop up but I can't get the text to print.
    Here is a sample from my previous post that I modified.
    G70
    G90
    [WINDOW ON]
    [CLS]
    [PRINT "CHECK THE HIGHLIGHTED LINE IN THE PROGRAM TO VERIFY"]
    [PRINT "THAT THE CURRENT ZSHIFT IS CORRECT"]
    [PRINT "IF THE THICKNESS IS NOT CORRECT, PLEASE CHANGE TO CORRECT"]
    M00
    SET ZSHIFT=0.250 (WASTEBOARD THICKNESS+MATERIAL THICKNESS)
    This is what I am getting right now.
    G70
    G90
    [WINDOW ON]
    [PRINTCHECK THE HIGHLIGHTED LINE IN THE PROGRAM TO VERIFY]
    [PRINTTHAT THE ZSHIFT IS CORRECT]
    M00
    SET ZSHIFT=.25 (WASTEBOARD+MATERIAL THICKNESS)
    Here is what I have in the post. I need to get the quotation marks added:
    n,measure_mode
    n,absolute_coord
    n,"[""WINDOW ON""]"
    n,"[""PRINT" "CHECK THE HIGHLIGHTED LINE IN THE PROGRAM TO VERIFY","]"
    n,"[""PRINT" "THAT THE ZSHIFT IS CORRECT""]"
    n,"M00"
    n,"SET ZSHIFT=.25"" ""(WASTEBOARD+MATERIAL THICKNESS)"
    n,"[""WINDOW OFF""]"
    Thanks,
    Zach
    No posers SBC Cycle's Avatar
    Apr 2008
    Default Re: Modifying Post
    The quote variable is what you want to use.
    Code:
    "[","PRINT ",quote,"CHECK THE HIGHLIGHTED LINE IN THE PROGRAM TO VERIFY",quote,"]"
    That should do the trick!
    Mastercam X9/2021 Multiaxis - Bobcad V21-V31 3ax Pro 4ax Std.
    Jan 2005
    Thanks,
    That worked great.
    What would be the best way to add a space in a line?
    Thanks,
    Zach
    Apr 2008
    Kinda crude but literally just programming a space if necessary (you can see I added one after PRINT above):
    Code:
    You can play with default_add_spaces but sometimes it doesn't really do what you need.
Modifying Post
Modifying Post
