Need Help! Having problems with Cutter path not completing cut (PICS)
Results 1 to 5 of 5
Thread: Having problems with Cutter path not completing cut (PICS)
    Sep 2017
    Default Having problems with Cutter path not completing cut (PICS)
    Im having a problem getting a 1/4 ball nose emill to go to the exact edges of the part.
    It will work great when at 90 degrees. but when I turn the tool to a 45 degree fix. ( for clearance ) the tool doesnt go the the exact edge of the part.
    Im still very new to working with cam software. So it could be something fairly easy.
    Works fine.
    Doesnt work
    ks
    Sep 2017
    Default Re: Having problems with Cutter path not completing cut (PICS)
    Come on... no one can help me with this one?
    Member The Engine Guy's Avatar
    Jun 2008
    UK
    Are you using "Tool Center" or "Tool Tip" ? ?
    Ghost BurrMan's Avatar
    Dec 2008
    Quote Originally Posted by SNZO View Post
    Little information has been provided. On the previous dialogue page, what is set for the "Area type"?
    There are also about 9 other things that can control that. Let alone I cant be sure WHICH TOOLPATH Strategy that even is!!!
    Zip and post the bbcd file would help.
    No posers SBC Cycle's Avatar
    Apr 2008
    Are you using any kind of tool containment strategy? If so, make sure it is properly projected while on a tilt. Sometimes it helps rotating the view in the workspace to look at the part the same way the tool will, looking straight down the shaft.
    Mastercam X9/2021 Multiaxis - Bobcad V21-V31 3ax Pro 4ax Std.
