Originally Posted by
RedStar2016
Here is a little back ground info.
I have replaced the computer that operates our plasma table as the fan cooked and we had another xp computer.
I loaded mach 3 and copied our licence over and everything works well except now the whenever I have a round part that has a protrusion or fillets the mach 3 doesn't know what to do and the part does not carry over. Im not good at the programming part of things and think it must be an easy fix but I cant seem to resolve. I changed the IJ to incremental and absolute and no luck. If someone has dealt with this or know of a fix I would greatly appreciate your input. Pictures are attached.
I would also like bobcad to not generate the following lines of code as i manually have to delete them otherwise my plasma will cut across the sheet when i completes a part. If someone knows about that too. Its not a big deal.
N19 G53 Z0
N20 G53 Y0
