Yes, long time.
I haven't seen that particular go by. And since I am limited, I would need more info/interaction.
Hard for me to start with "Canned cycles" like a tapping one.
The new material library carries cutting conditions. And then there is also cutting conditions that has IPM and IPR... (The post has a setting for this also)
The Material cutting condition deal with SFM... I don't know if there is something up with what you are seeing.
Can you provide a simple bbcd file, results your post gets, and what you expect, as a starting point?
