Well,it is a newer version than what I own.Ain't going to happen.
Why do you you have a .bbcd file to convert ?
Like it is a 2 second deal for the person who originally saved it,to save as a .dxf
I don't have bobcad. Can someone convert this .bbcd bobcad file to an eps or dxf so I can import into my software.
Thanks in advance!
It's a part I need to modify slightly for fire dept's Hmmwv. I'm working through owner of company that makes the part, someone else does their drawings and lost in translation. Seemed easier to get someone with bobcad to convert to what I can use than to try to explain what is needed through multiple layers of folks.
The ,bbcd file is newer than V28,,,,Hopefully someone who owns V29 or 30 can help
Try the attached .DXF file, should work, all errors and ommissions excepted, use at your own risk
We have to say such things these days just to cover backs etc
jrmach FYI for future reference. File was opened in V29 Demo and as it is just lines and arcs all I did was highlight it all and go Edit>Copy, this puts it on Windows Clipboard.
Next opened up V28 and went Edit>Paste and the shape then appeared in the new document, then a simple "Save as" to .dxf and job done
Regards
Rob
You are welcome
Regards
Rob
