Need Help! New to embossing in V27
Results 1 to 5 of 5
Thread: New to embossing in V27
    Dec 2012
    Default New to embossing in V27
    I am trying to emboss a simple vectorized sketch I created in a .bbcd file. I have engraved this file with no problem. I saved the file with a new name, bbcd file. When I open the new file the Data-Cam Tree and drawing open normally. When I select Bobart the Emboss Model disappears from the tree. I see file ext. that can be embossed. I saved file with .stl ext. Same result. How do I get this to work?
    Ghost BurrMan's Avatar
    Dec 2008
    Quote Originally Posted by Podunk View Post
    Its a bit difficult to understand what you are asking and whats been done.
    I could help you but i need a better description. Maybe a zipped bbcd file? Or do a better step by step description.
    Mar 2014
    Default Re: New to embossing in V27
    I am new so If this is not right sorry. I have tried to emboss a image that i have all ready have in the cam tree and it didn't work. i had to start over with just the image file in bobart. pick you stock then emboss and start a new cam tree. just trying to help. Not to sure about this.
    - - - Updated - - -
    Apr 2009
    I don't follow with you,BUT,hopefully this can help you https://www.youtube.com/results?sear...=emboss+bobcad
    Dec 2012
    racer6,
    That is what I ended up doing. Tech suggested that I had a corrupted file??? I started a new file,scanned hand drawn sketch,traced that, then embossed and toolpathed. Worked. From now on I'll start a new embossing file from scratch. Thanks for the suggestion.
