Need Help!- Using Bobcad v23 to generate g code for Linuxcnc controller on 2 1/2 axes mill
Using Bobcad v23 to generate g code for Linuxcnc controller on 2 1/2 axes mill. I currently have a sid script that allows for a pause to change z axes, that works on the sample logo code in the linuxcnc software. If I open in linuxcnc a simple profile created in Bobcad (post and saved) there is an error "o word". Attached are the files in question, hope they open ok, renamed to .txt. The post processor is a FunucOM. The .ini file has a FILTER that allows .ngc or .NC file to open. If there is suggested reading please comment where and what, please.
many thanks!! Similar Threads:
Re: Using Bobcad v23 to generate g code for Linuxcnc controller on 2 1/2 axes mill
I will try this again, many thanks, to you The Engine Guy!
The logo code will work, the pause is ok. The test funuc file is what Bobcad provides for a simple profile of 2 islands inside square border. Any help or suggested reading would be greatly appreciated.
many thanks!
Edit: the logo file did not load correctly, so try copy and paste.
( AXIS "splash g-code" Not intended for actual milling )
(Z axis)
( depending on your setup. As if you had some material in your mill... )
(Z axis down a bit then touch off )
( Also press the Toggle Skip Lines with "/" to see that part )
( If the program is too big or small for your machine, change the scale below )
( LinuxCNC 19/1/2012 2:13:51 PM )
#<depth>=2.0
#<scale>=1.0
G21 G90 G64 G40
M0G0 (Z3.0)
( engraving )
G17
M3 S10000
G0 X[1.75781*#<scale>] Y[0.5*#<scale>]
M0G1 F100.0 (Z[-#<depth>])
G1 F400.0 X[5.95508*#<scale>] Y[20.54297*#<scale>]
G1 X[10.07031*#<scale>]
G1 X[6.58398*#<scale>] Y[3.84961*#<scale>]
G1 X[16.7832*#<scale>]
G1 X[16.08594*#<scale>] Y[0.5*#<scale>]
G1 X[1.75781*#<scale>]
M0G0 (Z3.0)
G0 X[18.72461*#<scale>]
G1 F400.0 X[21.75977*#<scale>] Y[15.01953*#<scale>]
G1 X[25.68359*#<scale>]
G1 X[22.64844*#<scale>] Y[0.5*#<scale>]
G1 X[18.72461*#<scale>]
M0G0 (Z3.0)
G0 X[26.55859*#<scale>]
G1 F400.0 X[29.59375*#<scale>] Y[15.01953*#<scale>]
G1 X[33.3125*#<scale>]
G1 X[32.92969*#<scale>] Y[13.13281*#<scale>]
G2 X[34.16342*#<scale>] Y[14.08624*#<scale>] I[8.82141*#<scale>] J[-10.13994*#<scale>]
G2 X[35.52734*#<scale>] Y[14.8418*#<scale>] I[4.53823*#<scale>] J[-6.58354*#<scale>]
G2 X[38.08398*#<scale>] Y[15.36133*#<scale>] I[2.53506*#<scale>] J[-5.9247*#<scale>]
G2 X[39.5966*#<scale>] Y[15.13543*#<scale>] I[0.06403*#<scale>] J[-4.74845*#<scale>]
G2 X[40.90039*#<scale>] Y[14.33594*#<scale>] I[-1.02874*#<scale>] J[-3.14049*#<scale>]
G2 X[41.7019*#<scale>] Y[13.08328*#<scale>] I[-2.33045*#<scale>] J[-2.37388*#<scale>]
G2 X[41.93945*#<scale>] Y[11.61523*#<scale>] I[-4.07102*#<scale>] J[-1.41199*#<scale>]
G2 X[41.76899*#<scale>] Y[10.15744*#<scale>] I[-10.17473*#<scale>] J[0.45091*#<scale>]
G2 X[41.48828*#<scale>] Y[8.7168*#<scale>] I[-39.45138*#<scale>] J[6.93932*#<scale>]
G1 X[39.7793*#<scale>] Y[0.5*#<scale>]
G1 X[35.85547*#<scale>]
G1 X[37.57813*#<scale>] Y[8.74414*#<scale>]
G3 X[37.79665*#<scale>] Y[9.84001*#<scale>] I[-62.81729*#<scale>] J[13.09579*#<scale>]
G3 X[37.96094*#<scale>] Y[10.94531*#<scale>] I[-9.6524*#<scale>] J[1.99958*#<scale>]
G3 X[37.50977*#<scale>] Y[12.12109*#<scale>] I[-1.54162*#<scale>] J[0.0829*#<scale>]
G3 X[36.2793*#<scale>] Y[12.55859*#<scale>] I[-1.13356*#<scale>] J[-1.23903*#<scale>]
G3 X[35.26888*#<scale>] Y[12.33731*#<scale>] I[0.05277*#<scale>] J[-2.65845*#<scale>]
G3 X[34.36523*#<scale>] Y[11.83398*#<scale>] I[1.956*#<scale>] J[-4.57455*#<scale>]
G3 X[32.71094*#<scale>] Y[9.91992*#<scale>] I[2.86418*#<scale>] J[-4.1474*#<scale>]
G3 X[32.13267*#<scale>] Y[8.21493*#<scale>] I[8.76492*#<scale>] J[-3.92328*#<scale>]
G3 X[31.72656*#<scale>] Y[6.46094*#<scale>] I[36.34493*#<scale>] J[-9.33906*#<scale>]
G1 X[30.48242*#<scale>] Y[0.5*#<scale>]
G1 X[26.55859*#<scale>]
M0G0 (Z3.0)
G0 X[26.09375*#<scale>] Y[16.98828*#<scale>]
G1 F400.0 X[22.16992*#<scale>]
G1 X[22.9082*#<scale>] Y[20.54297*#<scale>]
G1 X[26.83203*#<scale>]
G1 X[26.09375*#<scale>] Y[16.98828*#<scale>]
M0G0 (Z3.0)
G0 X[46.14777*#<scale>] Y[12.78778*#<scale>]
G1 F400.0 X[46.61523*#<scale>] Y[15.01953*#<scale>]
G1 X[50.53906*#<scale>]
G1 X[48.74805*#<scale>] Y[6.41992*#<scale>]
G3 X[48.55485*#<scale>] Y[5.46101*#<scale>] I[39.83359*#<scale>] J[-8.52447*#<scale>]
G3 X[48.41992*#<scale>] Y[4.49219*#<scale>] I[7.34343*#<scale>] J[-1.51652*#<scale>]
G3 X[48.88477*#<scale>] Y[3.41211*#<scale>] I[1.45252*#<scale>] J[-0.01493*#<scale>]
G3 X[50.07422*#<scale>] Y[2.96094*#<scale>] I[1.13093*#<scale>] J[1.18803*#<scale>]
G3 X[51.09961*#<scale>] Y[3.15234*#<scale>] I[-0.00663*#<scale>] J[2.87782*#<scale>]
G3 X[52.13867*#<scale>] Y[3.75391*#<scale>] I[-1.85377*#<scale>] J[4.40013*#<scale>]
G3 X[53.0957*#<scale>] Y[4.68359*#<scale>] I[-3.51724*#<scale>] J[4.57812*#<scale>]
G3 X[53.88867*#<scale>] Y[6.05078*#<scale>] I[-4.71119*#<scale>] J[3.64605*#<scale>]
G3 X[54.44922*#<scale>] Y[8.10156*#<scale>] I[-12.97687*#<scale>] J[4.64901*#<scale>]
G1 X[55.89844*#<scale>] Y[15.01953*#<scale>]
G1 X[59.82227*#<scale>]
G1 X[56.78711*#<scale>] Y[0.5*#<scale>]
G1 X[53.12305*#<scale>]
G1 X[53.5332*#<scale>] Y[2.46875*#<scale>]
G2 X[51.14513*#<scale>] Y[0.79202*#<scale>] I[-6.21919*#<scale>] J[6.3187*#<scale>]
G2 X[48.29688*#<scale>] Y[0.1582*#<scale>] I[-2.84268*#<scale>] J[6.05776*#<scale>]
G2 X[46.78426*#<scale>] Y[0.3841*#<scale>] I[-0.06403*#<scale>] J[4.74845*#<scale>]
G2 X[45.48047*#<scale>] Y[1.18359*#<scale>] I[1.02874*#<scale>] J[3.14049*#<scale>]
G2 X[44.68637*#<scale>] Y[2.45262*#<scale>] I[2.34744*#<scale>] J[2.35189*#<scale>]
G2 X[44.45508*#<scale>] Y[3.93164*#<scale>] I[4.23866*#<scale>] J[1.42044*#<scale>]
G2 X[44.63379*#<scale>] Y[5.43705*#<scale>] I[10.83187*#<scale>] J[-0.52256*#<scale>]
G2 X[44.91992*#<scale>] Y[6.92578*#<scale>] I[45.15644*#<scale>] J[-7.90718*#<scale>]
G1 X[46.14777*#<scale>] Y[12.78778*#<scale>]
M0G0 (Z3.0)
G0 X[61.99609*#<scale>] Y[15.01953*#<scale>]
G1 F400.0 X[66.16602*#<scale>]
G1 X[68.28516*#<scale>] Y[10.87695*#<scale>]
G1 X[71.96289*#<scale>] Y[15.01953*#<scale>]
G1 X[76.73438*#<scale>]
G1 X[69.99414*#<scale>] Y[7.48633*#<scale>]
G1 X[73.6582*#<scale>] Y[0.5*#<scale>]
G1 X[69.48828*#<scale>]
G1 X[67.39648*#<scale>] Y[4.57422*#<scale>]
G1 X[63.78711*#<scale>] Y[0.5*#<scale>]
G1 X[58.97461*#<scale>]
G1 X[65.6875*#<scale>] Y[7.9375*#<scale>]
G1 X[61.99609*#<scale>] Y[15.01953*#<scale>]
M0G0 (Z3.0)
G0 X[78.12067*#<scale>] Y[11.80439*#<scale>]
G2 F400.0 X[78.15861*#<scale>] Y[11.98873*#<scale>] I[14.86609*#<scale>] J[-2.96421*#<scale>]
G2 X[79.20898*#<scale>] Y[15.0332*#<scale>] I[13.03118*#<scale>] J[-2.79244*#<scale>]
G2 X[80.8214*#<scale>] Y[17.48665*#<scale>] I[10.09107*#<scale>] J[-4.87534*#<scale>]
G2 X[83.06445*#<scale>] Y[19.38086*#<scale>] I[7.26534*#<scale>] J[-6.32817*#<scale>]
G2 X[88.42383*#<scale>] Y[20.88477*#<scale>] I[5.2993*#<scale>] J[-8.5834*#<scale>]
G2 X[91.21708*#<scale>] Y[20.49528*#<scale>] I[0.10667*#<scale>] J[-9.44597*#<scale>]
G2 X[93.6875*#<scale>] Y[19.13477*#<scale>] I[-1.95281*#<scale>] J[-6.46904*#<scale>]
G2 X[95.32764*#<scale>] Y[16.9908*#<scale>] I[-4.27639*#<scale>] J[-4.97078*#<scale>]
G2 X[96.05273*#<scale>] Y[14.39063*#<scale>] I[-7.426*#<scale>] J[-3.47204*#<scale>]
G1 X[92.10156*#<scale>] Y[14.00781*#<scale>]
G3 X[91.68364*#<scale>] Y[15.38196*#<scale>] I[-5.83945*#<scale>] J[-1.02535*#<scale>]
G3 X[90.83008*#<scale>] Y[16.53711*#<scale>] I[-2.94269*#<scale>] J[-1.28147*#<scale>]
G3 X[89.65745*#<scale>] Y[17.15799*#<scale>] I[-2.02111*#<scale>] J[-2.39937*#<scale>]
G3 X[88.3418*#<scale>] Y[17.33008*#<scale>] I[-1.26203*#<scale>] J[-4.53327*#<scale>]
G3 X[85.14258*#<scale>] Y[16.29102*#<scale>] I[0.01526*#<scale>] J[-5.49164*#<scale>]
G3 X[83.72532*#<scale>] Y[14.83462*#<scale>] I[3.39082*#<scale>] J[-4.71749*#<scale>]
G3 X[82.77734*#<scale>] Y[13.03711*#<scale>] I[7.50088*#<scale>] J[-5.10456*#<scale>]
G3 X[81.88867*#<scale>] Y[8.63477*#<scale>] I[10.80218*#<scale>] J[-4.47143*#<scale>]
G3 X[82.12643*#<scale>] Y[6.67148*#<scale>] I[7.47758*#<scale>] J[-0.09047*#<scale>]
G3 X[83.03711*#<scale>] Y[4.91602*#<scale>] I[4.24649*#<scale>] J[1.08898*#<scale>]
G3 X[85.92188*#<scale>] Y[3.60352*#<scale>] I[2.82627*#<scale>] J[2.38541*#<scale>]
G3 X[88.84766*#<scale>] Y[4.64258*#<scale>] I[0.00074*#<scale>] J[4.63663*#<scale>]
G3 X[90.07896*#<scale>] Y[6.0293*#<scale>] I[-3.23186*#<scale>] J[4.10967*#<scale>]
G3 X[90.84375*#<scale>] Y[7.71875*#<scale>] I[-6.5029*#<scale>] J[3.96159*#<scale>]
G1 X[95.0*#<scale>] Y[7.08984*#<scale>]
G2 X[93.56373*#<scale>] Y[4.23114*#<scale>] I[-11.87256*#<scale>] J[4.17484*#<scale>]
G2 X[91.34961*#<scale>] Y[1.92188*#<scale>] I[-7.88363*#<scale>] J[5.34275*#<scale>]
G2 X[88.64367*#<scale>] Y[0.56922*#<scale>] I[-5.3138*#<scale>] J[7.24715*#<scale>]
G2 X[85.64844*#<scale>] Y[0.14453*#<scale>] I[-2.92298*#<scale>] J[9.84046*#<scale>]
G2 X[82.5341*#<scale>] Y[0.63758*#<scale>] I[-0.13266*#<scale>] J[9.24446*#<scale>]
G2 X[79.89258*#<scale>] Y[2.35938*#<scale>] I[2.19287*#<scale>] J[6.25138*#<scale>]
G2 X[78.25253*#<scale>] Y[5.37699*#<scale>] I[5.36449*#<scale>] J[4.87005*#<scale>]
G2 X[77.82813*#<scale>] Y[8.78516*#<scale>] I[12.16539*#<scale>] J[3.2454*#<scale>]
G2 X[78.12067*#<scale>] Y[11.80439*#<scale>] I[15.15864*#<scale>] J[0.05503*#<scale>]
M0G0 (Z3.0)
G0 X[98.14159*#<scale>] Y[7.6254*#<scale>]
G1 F400.0 X[100.83789*#<scale>] Y[20.54297*#<scale>]
G1 X[104.69336*#<scale>]
G1 X[110.12109*#<scale>] Y[7.13086*#<scale>]
G1 X[112.92383*#<scale>] Y[20.54297*#<scale>]
G1 X[116.75195*#<scale>]
G1 X[112.56836*#<scale>] Y[0.5*#<scale>]
G1 X[108.72656*#<scale>]
G1 X[103.3125*#<scale>] Y[13.9668*#<scale>]
G1 X[100.49609*#<scale>] Y[0.5*#<scale>]
G1 X[96.6543*#<scale>]
G1 X[98.14159*#<scale>] Y[7.6254*#<scale>]
M0G0 (Z3.0)
G0 X[118.27432*#<scale>] Y[8.23889*#<scale>]
G2 F400.0 X[118.26953*#<scale>] Y[8.78516*#<scale>] I[12.585*#<scale>] J[0.3835*#<scale>]
G2 X[118.60002*#<scale>] Y[11.98873*#<scale>] I[15.15864*#<scale>] J[0.05503*#<scale>]
G2 X[119.65039*#<scale>] Y[15.0332*#<scale>] I[13.03118*#<scale>] J[-2.79244*#<scale>]
G2 X[121.26281*#<scale>] Y[17.48665*#<scale>] I[10.09107*#<scale>] J[-4.87534*#<scale>]
G2 X[123.50586*#<scale>] Y[19.38086*#<scale>] I[7.26534*#<scale>] J[-6.32817*#<scale>]
G2 X[128.86523*#<scale>] Y[20.88477*#<scale>] I[5.2993*#<scale>] J[-8.5834*#<scale>]
G2 X[131.65849*#<scale>] Y[20.49528*#<scale>] I[0.10667*#<scale>] J[-9.44597*#<scale>]
G2 X[134.12891*#<scale>] Y[19.13477*#<scale>] I[-1.95281*#<scale>] J[-6.46904*#<scale>]
G2 X[135.76904*#<scale>] Y[16.9908*#<scale>] I[-4.27639*#<scale>] J[-4.97078*#<scale>]
G2 X[136.49414*#<scale>] Y[14.39063*#<scale>] I[-7.426*#<scale>] J[-3.47204*#<scale>]
G1 X[132.54297*#<scale>] Y[14.00781*#<scale>]
G3 X[132.12504*#<scale>] Y[15.38196*#<scale>] I[-5.83945*#<scale>] J[-1.02535*#<scale>]
G3 X[131.27148*#<scale>] Y[16.53711*#<scale>] I[-2.94269*#<scale>] J[-1.28147*#<scale>]
G3 X[130.09886*#<scale>] Y[17.15799*#<scale>] I[-2.02111*#<scale>] J[-2.39937*#<scale>]
G3 X[128.7832*#<scale>] Y[17.33008*#<scale>] I[-1.26203*#<scale>] J[-4.53327*#<scale>]
G3 X[125.58398*#<scale>] Y[16.29102*#<scale>] I[0.01526*#<scale>] J[-5.49164*#<scale>]
G3 X[124.16673*#<scale>] Y[14.83462*#<scale>] I[3.39082*#<scale>] J[-4.71749*#<scale>]
G3 X[123.21875*#<scale>] Y[13.03711*#<scale>] I[7.50088*#<scale>] J[-5.10456*#<scale>]
G3 X[122.33008*#<scale>] Y[8.63477*#<scale>] I[10.80218*#<scale>] J[-4.47143*#<scale>]
G3 X[122.56784*#<scale>] Y[6.67148*#<scale>] I[7.47758*#<scale>] J[-0.09047*#<scale>]
G3 X[123.47852*#<scale>] Y[4.91602*#<scale>] I[4.24649*#<scale>] J[1.08898*#<scale>]
G3 X[126.36328*#<scale>] Y[3.60352*#<scale>] I[2.82627*#<scale>] J[2.38541*#<scale>]
G3 X[129.28906*#<scale>] Y[4.64258*#<scale>] I[0.00074*#<scale>] J[4.63663*#<scale>]
G3 X[130.52037*#<scale>] Y[6.0293*#<scale>] I[-3.23186*#<scale>] J[4.10967*#<scale>]
G3 X[131.28516*#<scale>] Y[7.71875*#<scale>] I[-6.5029*#<scale>] J[3.96159*#<scale>]
G1 X[135.44141*#<scale>] Y[7.08984*#<scale>]
G2 X[134.00514*#<scale>] Y[4.23114*#<scale>] I[-11.87256*#<scale>] J[4.17484*#<scale>]
G2 X[131.79102*#<scale>] Y[1.92188*#<scale>] I[-7.88363*#<scale>] J[5.34275*#<scale>]
G2 X[129.08508*#<scale>] Y[0.56922*#<scale>] I[-5.3138*#<scale>] J[7.24715*#<scale>]
G2 X[126.08984*#<scale>] Y[0.14453*#<scale>] I[-2.92298*#<scale>] J[9.84046*#<scale>]
G2 X[122.9755*#<scale>] Y[0.63758*#<scale>] I[-0.13266*#<scale>] J[9.24446*#<scale>]
G2 X[120.33398*#<scale>] Y[2.35938*#<scale>] I[2.19287*#<scale>] J[6.25138*#<scale>]
G2 X[118.69393*#<scale>] Y[5.37699*#<scale>] I[5.36449*#<scale>] J[4.87005*#<scale>]
G2 X[118.27432*#<scale>] Y[8.23889*#<scale>] I[12.16539*#<scale>] J[3.2454*#<scale>]
M0G0 (Z3.0)
M5
M2
Reason: copy and paste
Does anyone recognize the g code format shown above? This code works, the file attached "testfanuc01" is the format Bobcad uses, how or what is it I need to find or research? Is there any suggested reading?
many thanks for any thoughts?
Forum Rules
