Hi Daniel, try running the function "Reorganize" on your geometry after opening/merging in the dxf. It's also possible when exporting from Solidworks it is converting your arcs into segments. Check those settings as well. I'm not quite clear on the nature of your problem from the description you gave. Got a file sample you can upload?
