Need Help! Boundaries
Results 1 to 16 of 16
Thread: Boundaries
    May 2005
    Default Boundaries
    I'm using v26 and am having a helluva a time trying to select boundaries. I want to do this part in sections and I followed videos on boundary selection but BC seems to be ignoring what I select. For example look at my screen shot titled geometry,I want the tool just to do the selected parts, yet it generates toolpath for the whole dam thing. I also select a boundary see boundary pic because I don't want the tool cutting on the top because it's a mold. I've tried extracting edges for wire frames, using the wire frame to select the boundary, going around trying all sorts of combinations clicking on geometry sections, which is a tedious time consuming PITA, particularly when it just ignores what you select.
    Is there some way to do this when you actually select sections of geometry, it does just those sections and nothing else? The latest video I'm following is this one.
    Attached Thumbnails Attached Thumbnails Boundaries-geometry-jpg   Boundaries-boundary-jpg
    No posers SBC Cycle's Avatar
    Apr 2008
    Default Re: Boundaries
    It looks like you are using a "stock aware" operation (Advanced/Adaptive Rough, Z level rough, etc.)
    In short, BobCAD looks at the geometry you want to machine, sees all that stock (in shaded blue) and tries to remove the excess. Your boundary is including all that space to right where there is "stock" but no geometry. It's trying to remove it.
    Shorten up your boundary to only include the areas where you have selected geometry. The boundary needn't be 2D but it must be a closed shape. You can get creative.
    Mastercam X9/2021 Multiaxis - Bobcad V21-V31 3ax Pro 4ax Std.
    Apr 2009
    Just to be clear,,,for geometry selection,,,you select the entire model
    The Boundaries will limit the area..Top of job and bottom of job can be used too,to further limit the tool path
    May 2005
    Wow BC is really counter intuitive. Whats the point of even having a "select geometry" option if it ignores it? The video I linked to thats all he is doing selecting the part of the piece he wants machined. The fact that material is elseware on the part should be irrelevant, the fact the boundary extends beyond the selected geometry should also be irrelevant, they aren't selected for machining.The boundary should just apply to the selected geometry area and be ignored outside of that area because nothing is selected for machining there. So I now have to dick around with wireframes, Christ what a tedious CAD tool.
    Apr 2009
    Re-watch video,,,,you not understanding all that Al says,,,,he is spot on and will make sense with time
    A word about wire frame,,,using wire frame 2d or 3d,,if you use the wireframe as a boundary,,,even the 3d,, the software will see only as a 2d top view
    the wire frame also must be a closed loop
    Don't get confused about the 3d wireframe when used as geometry for 3d engraving,,,,,2 completely different things
    Apr 2009
    Whats so tedious about getting wire frame ?
    I can get it pretty darn fast.
    Keep asking questions
  7. #7
    May 2005
    Quote Originally Posted by jrmach View Post
    Its all one wire along the side so I'm guessing it has to be broken or added to in order to close the loop.
    I have to go out now but I appreciate the help, I'm just getting frustrated, for something that should be straight forward for this type of tool its tedious. my eyes are starting to bug out of my head from trying to grab the small sections.
    I changed my approach and did the front part first and it seems to actually be staying where I want it.
    Attached Thumbnails Attached Thumbnails Boundaries-boundjpg-jpg
  8. #8
    Apr 2009
    I just did a video of one way to do your boundary
    There are many other ways also
    as SBC said above "The boundary needn't be 2D but it must be a closed shape. You can get creative."
    here i got a little creative as i choose to translate and extend that last line to complete my boundary
    In newer versions,there is even more and better ways,,,but V26,I choose this way as i thought it was fast enough.Seems like a lot of work,but you get use to entity summary and translate and the trim functions,,,etc. it goes fast
    anyhow,waiting on you tube and then i will post a link,,,,,,Note:I did not mess with your Cam selections of tool path at all,,the purpose of this was to show you Boundaries
  9. #9
    Apr 2009
  10. #10
    May 2005
    I really appreciate all your help jrmach. I just got in and will try again tomorrow, been a long day. Time for a cold beer and to relax for a while.
  11. #11
    Member aldepoalo's Avatar
    Mar 2012
    Jake,
    This is a great question and gets new users hung up all the time. So what I recommend is that you select all of your part geometry when using 3D toolpaths. Yes you have the option to select groups of surfaces, but other trouble pops up and running V26 Mill standard doesn't have the tools to check surfaces away etc... Also I don't think at this time you have a clear understand of how the toolpath is being created based on your selection and inputs.
    So what to do to get the results you are after with the tools you have?
    A- Select all of the part model when creating toolpath
    Boundaries-1-jpg
    B- Use boundaries to control where the toolpath is created in X and Y
    Boundaries-2-jpg
    Boundaries-3-jpg
    Keeping your boundary simple makes it easy to select. For cavity work like this it's not necessary to create a more complicated boundary.
    C- Use top of job , bottom of job to control where toolpath is created in Z
    Boundaries-5-jpg
    Watch this video for the work flow.
    Al DePoalo
    Partner Product Manager BobCAD CAM, Inc. 866-408-3226 X147
  12. #12
    May 2005
    Can't thank you guys enough. I was almost ready to toss my PC through the window. Now I can concentrate just on the machine strategy and tooling.
  13. #13
    Mar 2012
    Once you gain better understanding of the toolpath setup and how to use boundaries you can create a cutting path to work from the inside out vs running from one end to another.
    Boundaries-8-jpg
    Boundaries-6-jpg
    Boundaries-7-jpg
    Al DePoalo
  14. #14
    Apr 2009
    Jake,if you saw what Pro Mill had to offer in 28 and 29,,,well that's another story
    If you are going to be doing lots of parts like the one you are now,,,I personally would be asking for a Brother-n-Law deal for an upgrade to Pro,,,,IMOP
  15. #15
    May 2005
    Thats not upto me. I think he is waiting to see how things go, before he invest anymore money. I'm using the PRO version of 26 by the way not standard.
    Thanks for taking the time to post the video jrmach, it was helpful.
  16. #16
    Apr 2008
    Great videos all! It's easy to forget the Top of Job and Bottom of job settings. There are numerous ways to contain your geometry, I choose the most logical first and if there is no logical choice I go with the easiest. Glad to see you're getting it Jake!
Boundaries
Boundaries
