Page 1 of 2 12 LastLast
Results 1 to 12 of 24
Thread: (spine (print not to scale)
    Apr 2004
    Grafton N.H.
    Hello All! I have made a small open ended spline obout 3 inchs long.
    When i print out the cad drawing it is about 3/4 scale.(about 2 inchs long) The scale in the lower right hand of the drawing says 1 ... I also drew a 2 inch square box and a 4 inch circle and they print out to size correctly.
    what am i doing wrong? Thank you very much.....Dean
    Moderator tobyaxis's Avatar
    Jan 2006
    Quote Originally Posted by dneufell View Post
    Have you looked at your printer settings?
    Toby D.
    "Imagination and Memory are but one thing, but for divers considerations have divers names"
    Schwarzwald
    www.refractotech.com
    Apr 2004
    Grafton N.H.
    Hi Toby....Printer settings? In Bobcad? In Print setup it just asks for the type
    of printer i have,paper size and orientation of the paper....in bobcad the print button opens a dialoge box of drawing scale ,scale 1:1 and fit all bullet. I have tryed all three and the same thing happens....the circle and square come out to size but the spline does not...Thank you .....Dean
    Jan 2006
    Have you called BCC Support or Posted in their Support Forum?
    http://216.117.147.20/bobcadsupport/forums/
    Toby D.
    Schwarzwald
    Aug 2003
    This issue seems odd...afterall a Spline in Version 21 is just a series of lines and arcs, it is not really a Spline.
    Could you post the file for us to see? It may be something that I can even help with.
    Regards
    Apr 2004
    Grafton N.H.
    Spline print
    Hello All! I also have tryed this on Bobcad ver19 with the same results.
    The 4 inch circle and the 3 inch square printed right to size. The spline printed about .600 short on the over all length......Thank you....Dean
    Apr 2004
    Grafton N.H.
    {{To attach a file to a new post, simply click the [Manage Attachments] button at the bottom of the post composition page, and locate the file that you want to attach from your local hard drive.
    After posting, the image attachments may display a thumbnail, depending on the forum settings. To view the contents of the attachment (if it is not already displayed) simply click the filename link that appears next to the attachment icon.}}
    I have tryed to attach the cad file to this post....it asked me to to look thru
    my harddrive to find the file which i did and to press the upload button.....
    I must have done something wrong.....back to the drawing board!!!!
    Apr 2004
    Grafton N.H.
    2nd try
    1st try Bobcad cad file
    2nd try Bobcad dxf file
    ......Dean
    Attached Files Attached Files
    Jan 2006
    There is a List of Uploadable Files in the Attachments Window. This Forum won't accept BCC CAD files. You would have too Zip them using this www.filzip.com
    BCC's forum will accept BCC Files though. http://216.117.147.20/bobcadsupport/forums/
    Attached Thumbnails Attached Thumbnails (spine (print not to scale)-attachments_list.jpg
    Toby D.
    Schwarzwald
    Aug 2003
    The dxf file printed just fine. There were no discrepencies between the image size and the printed size. Do you get the same result when printing the dxf file as you do when printing the cad file?
    Regards
    Apr 2004
    Grafton N.H.
    spline print
    I must be explaining it wrong......I have a shape to cut on the mill.
    the length is 3.625 How i drew the spline is i have a paper cutout of the shape that i taped to the computer screen. I placed the points along the edge and then slected spine to make the points blend. Print function says 1:1 scale is at 1 It prints the spline length about 3.0 (but the circle and square print right to size) Thanks....Dean
    Apr 2004
    Grafton N.H.
    Yes same result when printing the cad file and dxf file.....Thanks.....Dean
  • Page 1 of 2 12 LastLast
    1. How to print ion a 3d surface
      By whiteriver in forum Printing, Scanners, Vinyl cutting and Plotters
      Last Post: 01-20-2010, 04:39 PM
    2. cant print?
      By erase42 in forum BobCad-Cam
      Last Post: 11-30-2009, 09:05 AM
    3. Need to make scale tire mold for 1/6 scale car
      By thuffner3 in forum Moldmaking
      Last Post: 04-29-2008, 01:57 AM
    4. z-axes print
      By promass in forum Bridgeport and Hardinge Mills
      Last Post: 07-24-2007, 01:47 PM
    5. 2d print from solidworks
      By Kool Parts in forum Solidworks
      Last Post: 02-03-2005, 10:12 AM
