Need Help! Peck Tapping in BobCAD ?
Results 1 to 4 of 4
Thread: Peck Tapping in BobCAD ?
    Oct 2009
    Default Peck Tapping in BobCAD ?
    Hey guys,
    Running Bobcad V28. The does a lot hole tapping on the Haas VF3-YT50. Material is 304SS. Is it possible to Peck Tap in Bobcad? I don't see an option for it like there is for drilling. I know the Haas is capable of it by turning on setting 133. This makes the spindle orient each time it enters the hole.
    Here is a snip of the code: (It's just doing a single depth) Would prefer multiple pecks to clear the hole out of chips.
    (TOOL #10 Badger UNC 5/8-11 Hand Tap)
    N917 T10 M06
    N919 T13
    N921 G90 G54 X1.5 Y2.1275 S98 M03
    N923 G43 H10 D10 Z1. M08
    N925 G00 Z-0.2
    N927 G95
    N929 G84 G99 X1.5 Y2.1275 Z-1.3506 R-0.3 F0.0909
    N931 G80
    N933 G94
    N935 G00 Z-0.2
    N937 Z1.
    In the Haas example on Youtube, they are showing multiple tap pecks.
    X0 Z-1. ;
    X0 Z-1.5 ;
    X0 Z-2. ;
    X0 Z-2.5 ;
    Any ideas?
    Thank you.
    Oct 2009
    Default Re: Peck Tapping in BobCAD ?
    If BobCAD doesn't support peck tapping for some reason, looks like I will have to Post the code and make the entries manually. Here is a better description of what peck tapping looks like. Taken from the Haas video.
    Attached Thumbnails Attached Thumbnails Peck Tapping in BobCAD ?-simple-peck-tapping-jpg
    Member aldepoalo's Avatar
    Mar 2012
    Peck tapping is not an in the box feature for the software, you could write a script to post code like the example above. Using the ADV posting tab the software api and a custom script you can format the code to do just about anything...
    Al DePoalo
    Partner Product Manager BobCAD CAM, Inc. 866-408-3226 X147
    Aug 2012
    We don't do much tapping, but below is another verified way to program with peck. The program is for a 304SS manifold. Bobcad may not have an option for peck tapping, but this is easy simple copy and paste. Running a Haas VF-3SSYT with Next Gen control here. Here's the peck portion of the program:
    (****** TOOL CHANGE *** T05 ***)
    (1/8-27 PIPE TAP NPT)
    N355 M06 T05
    N360 T01
    N365 G54
    N370 G90 G00 X-1.125 Y0. S150 M03
    N375 G43 Z.2 H05 M08
    N380 G98 G84 X-1.125 Y0. Z-.1962 R.2 F5.55
    N385 G84 Z-.3923
    N390 G84 Z-.6485
    N395 G84 X-1.625 Z-.1962
    N400 G84 Z-.3923
    N405 G84 Z-.6485
    N410 G84 X-2.125 Z-.1962
    N415 G84 Z-.3923
    N420 G84 Z-.6485
    N425 G84 X-2.625 Z-.1962
    N430 G84 Z-.3923
    N435 G84 Z-.6485
    N440 G84 X-3.125 Z-.1962
    N445 G84 Z-.3923
    N450 G84 Z-.6485
    N455 G84 X-3.625 Z-.1962
    N460 G84 Z-.3923
    N465 G84 Z-.6485
    N470 G84 X-4.125 Z-.1962
    N475 G84 Z-.3923
    N480 G84 Z-.6485
    N485 G84 X-4.625 Z-.1962
    N490 G84 Z-.3923
    N495 G84 Z-.6485
    N500 G84 X-5.125 Z-.1962
    N505 G84 Z-.3923
    N510 G84 Z-.6485
    N515 G84 X-5.625 Z-.1962
    N520 G84 Z-.3923
    N525 G84 Z-.6485
    N530 G84 X-6.125 Z-.1962
    N535 G84 Z-.3923
    N540 G84 Z-.6485
    N545 G84 X-6.625 Z-.1962
    N550 G84 Z-.3923
    N555 G84 Z-.6485
    N560 G80 M09
    (EOMP-RETURN TO PART CHANGE POS)
    N565 M98 P9002
    N570 M30
