Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > BobCad-Cam
BobCad-Cam Discuss all BobCad software here.
Old 03-01-2007, 03:05 PM
12jbowler is on a distinguished road
help
well my new project is to cut out a nautical star for a belt buckle and im using version 21 and bob-art...when I load the bitmap picture and vertorize the 2D, but when it vertorizes it makes the picture look terrible and theres zero straight lines left on it...im stil pretty new to bobcad and im tryin to be lazy and bring a picture into bocad from the internet and cut it without puttin a whole lot of work into it.....
thanks
Old 03-01-2007, 03:18 PM
tobyaxis's Avatar
Moderator
tobyaxis is on a distinguished road
thanks
Can you post your BitMap? I might be able to help you.
Toby D.
"Imagination and Memory are but one thing, but for divers considerations have divers names"
Schwarzwald
www.refractotech.com
Old 03-01-2007, 06:21 PM
erase42 is on a distinguished road
yes if you can post or give a link to the picture it would help. if the contrast between the star and the back ground is low you can get very fuzzy edges.
somewhere there is an option to include or exclude arcs. you can also eliminate chains of less than a specified number of either pixels or entities or something i cant recall, changing these values will help eliminate the fuzz, however you may still not be able to extract sharp edges due to the graphic itself. if you can open it in a photo editor, place a small perfectly white dot on each corner or intersection of the star. now open in it bobart and the corners will now be very easy to extract, simply place a point on each corner and connect with straight lines. Im not sure what a marine star is, but perhaps it would be easier to draw one up in cad? Im gonna go see if i can figure out what a marine star is, good luck
Lemon Curry??
Old 03-02-2007, 12:58 PM
http://www.google.com/imgres?imgurl=...%3Den%26sa%3DN
Old 03-02-2007, 09:15 PM
here you go, i hope thats what you need, its a 2 d cad file of the outline. if you were looking to go 3d with it let me know and ill add some depth to it.
Lemon Curry??
