can you be more specific about what it means?
Someone help figure this out ?
Doing a radius (fillet)
Yes,,those are real specs,,,,tight ,tight tolerance
I can do it if I manually place it,,but I would like to know how to do it
I put the radius (Red) by translating and draggin and so forth,,,,
It will work,,,but what is the smart way to do it ?
Hi James
Looked at the file and I am assuming that you know the point on the large circle where the fillet has to meet the circle, either by coordinate or angle from the cemtre.
If so then using the "Point on Entity" you can put a point on your circle, then all you need to do is the "Arc Fillet" from the end of your top line to the point you have just placed on the circle, very quick and easy.
That do it ? ? ?
Regards
Rob
:rainfro: :rainfro: :rainfro:
"Looked at the file and I am assuming that you know the point on the large circle where the fillet has to meet the circle"
That's just it,the print don't say.
I can get close enough and stay in tolerance with the math skills I have,but I was looking,just to learn something new
Think of the example I gave,now think of a 2" diameter EM profiling the shape.Where the point the EM has to move to not violate the rectangular box I drew and the point where the other part of the EM is just leaving the big arc..The point where the EM is just leaving the big arc is what I need to do a correct fillet.
The only way I know,which is not %100 correct,,,is to find the chord length oh the 2" circle with a .0055 rise and divide by 2.
You can see the way I am doing is not perfect,,,but it is good enough
That point wont be determined out there in space, as your math left you kindof guessing and coming up a bit short.
You would build the 1 inch circle in the center top point, then your outer ring will give you the tangent break point (The opposite sides)
Then you can dim angle the 2 areas opposite and rotate the arc into position.
Here's a file with 1 done and the second left to do the rotation on, to illustrate what I did.
Thank you....that's a little out of the ordinary call out on a print
Oh,I understand what you did,,thanx
I meant a 1 inch radius going up only .0055
They call it a "mute" There are 12 of them on the outside of a ring and 12 inside
The ring is only .160 wall thicness
Going to fun
No, you clued in me end,just needed that little bit more to do it
But it might be worthwhile to make,,Others might like to learn.There is a little more than meets the eye.
Here it is....
Nice
More than meets the Eye
