Need Help! Bobcad issue
Results 1 to 8 of 8
Thread: Bobcad issue
    Mar 2014
    Default Bobcad issue
    Need some help please. I am trying to figure out how to mill out the area between the 2 brown lines in the enclosed picture. I have tried evereything I know how to do but haven't had any luck. I have tried the pocket feature but when I used this it wants to pocket out the center section which is a hub area that needs to be left. When I choose profile and have to choose left or right compensation it makes my tool path correct for one but then other side will be wrong. Thanks in advance for any information !!
    Attached Thumbnails Attached Thumbnails Bobcad issue-img_0389-jpg
    Dec 2011
    Default Re: Bobcad issue
    bcnu,
    Can you attach a part file to be looked at. It is hard to say without looking at the selected geometry on the toolpath.
    Mar 2014
    You can ignore the lines in the middle , we tried that to see if it would clean up the area we wanted to mill out the pocket in. The area between the outside green line and the inside brown line is what i need to mill out
    Attached Files Attached Files
    Dec 2011
    bcnu,
    The issue is likely because your outer shape has gaps in it. This will prevent it from functioning correctly, as it won't notice the outer shape is water tight.
    Mar 2014
    I will take a look at that and see if that is the issue and let you know. Thanks
    Member The Engine Guy's Avatar
    Jun 2008
    UK
    Not sure if this is right, is the area shown on the image what you are looking to mill out ? ?
    Bobcad issue-pocket-problem-jpg
    If so then it was some of the geometry appeared to have double entities which when cleared away allowed the outer dotted circle and the inner shape to be selected and allowed the toolpath shown using a 0.75mm cutter on a small 10% stepover.
    If not then let us know which area it is
    Regards
    Rob
    :rainfro: :rainfro: :rainfro:
  7. #7
    Mar 2014
    SeanDa, that was the problem. Thanks for your help!!
  8. #8
    Mar 2014
    Thanks for your reply Engine Guy, SeanDa's reply was exactly what the problem was.
Bobcad issue
Bobcad issue
