Need Help! Bobcad is painfully slow on any computer V26 also tested demo V29. Why? - Page 3
Page 3 of 3 FirstFirst 123
Results 25 to 34 of 34
Thread: Bobcad is painfully slow on any computer V26 also tested demo V29. Why?
  1. #25
    Company Representative SeanDa's Avatar
    Dec 2011
    Default Re: Bobcad is painfully slow on any computer V26 also tested demo V29. Why?
    Burr,
    I put in a request for future versions to automatically set the graphics to the high performance card.
    Sean P Daugherty
    BobCAD-CAM Technician
    727-489-0003
  2. #26
    Gold Member BurrMan's Avatar
    Dec 2008
    Quote Originally Posted by SeanDa View Post
    Burr,
    Thank you kindly, sir.
    As an added note, for those "optimizing their system", i would look at disabling the onboard graphics at the bios. I'm not familiar with his bios but at the very least, it should have a "prefered device" setting. Such a righteous card he has!
    Now he can go back to performance options and set them to "beautiful" as opposed to performance. I think it was the dual graphics chips that made the difference...
  3. #27
    Dec 2011
    Burr,
    There is no need to disable at the bios, it can be done through the nvidia control panel as a global setting. Please look at the attached picture for reference.
    Bobcad is painfully slow on any computer V26 also tested demo V29.  Why?-capture-jpg
    Sean P Daugherty
    727-489-0003
  4. #28
    Mar 2003
    I'm not even sure that you can disable the onboard graphics in most newer laptops. Since most Intel CPU's now have decent onboard graphics, they use an automatic switching setup to keep the machine cooler, and extend battery life.
    When I first got my laptop, I looked in the bios to see if I could disable it, and couldn't find that option.
    UCCNC 2017 Screenset
    http://www.thecncwoodworker.com/2017.html
    http://www.thecncwoodworker.com/2010.html
    http://www.g-forcecnc.com/jointcam.html
  5. #29
    Dec 2011
    ger,
    I believe it varies by manufacturers. Some will give the option, others won't.
    Sean P Daugherty
    727-489-0003
  6. #30
    Dec 2008
    Burr,
    Yeah i got that part. It may be just me from a ways back when "2 cards and driver sets was a bad thing".....
    But ger chiming has me consider they have managed it better?
    For laptops (which i havent used) it may also be different because you dont have to denote which device to boot to, for monitors etc, which makes my point moot...
    But i would imagine he wants everything running off that card.
    Maybe the glodal settings on that driver can select the prefered also? As opposed to the program settings alone? (This is just for anything else as he got his bobcad straightened out now)
    Been eyeballing a new rig myself. Still havent decided if i'll stay xeon and qquadro or go i7 and titan!!!!
  7. #31
    Dec 2011
    Burr,
    The setting in the picture is the global setting, which you can define if you want the control panel to auto-select,use integrated by default, or use high performance by default.
    Sean P Daugherty
    727-489-0003
  8. #32
    Dec 2008
    Burr,
    Sorry Sean, didnt expand the picture on my phone... global it is!
    Thanks again!
  9. #33
    Mar 2017
    I think it is best to select the Nvidia card as needed. It runs hot and the fan is always running, which can be annoying if you are not using an app that needs it. After a few days of use on the large files, this card is very fast and instant. I tried copying and pasting the 11k elements to see where it would slow down, and easily over 50k elements is was not an issue. I did crash the app when I got over 100k elements. There is no need to turn off layers.
    Thanks for the help guys. I highly recommend the Nvidia GTX.
  10. #34
    Mar 2017
    Default Re: Bobcad is painfully slow on any computer V26 also tested demo V29. Why? SOLVED
    I cannot seem to change the status to solved. I can't edit the first post.
