sure,,,draw in 3D wire frame
Mill in 3D engrave,,using a thread mill
but
I would use a tapping head,like a tapmatic,on a manual machine.Faster than CNC
Hey guys,
I'm using V28. We have a job where we need to install M10 helicoils in aluminum. I have an M10 helicoil kit that comes with the STI tap. However in BC I don't see that these taps are supported in the thread type selection process. Is it possible to make this work?
Thanks.
but
Or you could just add the tap to the thread chart in bobcad.... You just need to know what the thread pitch of the tap is.
Work: Hurco VMX42/VMX50 - Shopsabre 4896 - HSMworks with Solidworks
Home: RF45 with Ajax CNC Controller - Fusion 360
Thread pitch of the helicoil tap should be the same as the finished thread size.
I quite like targeted ads if they're not intensely annoying so I'll enable ads when your advertisers stop using annoying sounds, annoying slideshows and annoying animations
Personally its such an easy thing to do manually why bother with a cad system to do tapping?
Nick,,,I have manually tapped 10's of thousands of holes with tap-a-matic
2 things
1-you don't need to tie up a $100,000 machine
2-it's faster
