Really needs you to upload a copy of your Post Processor to get it right.
Normally most PPs default to not having Cutter Compensation active, look in your PP at Blocks 2,3 and 4 for the line n,cc or n,force_cc
Possibly should look a bit like the PP shown below which is a Fanuc 0M PP.
2. Start of file Standard
"(PROGRAM NAME - ",prog_name,")"
"(POST - ",machine_make,machine_model,")"
"(DATE - ",output_date,")"
"(TIME - ",output_time,")"
user_comment_1
user_comment_2
user_comment_3
user_comment_4
user_comment_5
user_comment_6
user_comment_7
user_comment_8
user_comment_9
user_comment_10
user_comment_11
user_comment_12
user_comment_13
user_comment_14
user_comment_15
n,absolute_coord,cancel_drill_cycle,"G40",inch_mod e,"G17"
n,rapid_move,incremental_coord,"G28","Z0."
n,rapid_move,incremental_coord,"G28","X0.","Y0."
system_comment
feature_name_comment
n,t,"M06"
n,s,spindle_on
n,rapid_move,absolute_coord,work_coord,force_x,xr, force_y,yr,rotary_xyr_angle,
n,rapid_move,length_offset,coolant_on
output_rotary_angle
n,cc
3. Tool change
n,coolant_off
n,spindle_off
n,optional_stop
system_comment
n_forced,t,"M06"
n,s,spindle_on
output_rotary_angle
n,cc
4. Null tool change
system_comment
n,s
n,rapid_move,force_x,xr,force_y,yr,rotary_xyr_angl e,
output_rotary_angle
n,cc
[COLOR="#000000"]It might need a d_offset inserting as well so it may need to be something like :-
n,d_offset,cc
but I would try just using the line n,cc first
Hope that`s of some help
Regards
Rob
:rainfro: :rainfro: :rainfro:
