Save as Part Name Rev2.xxx
I would charge the customer for the CAM time for the new part design. Adding a feature might change everything.
I have a 3d cad file that I already did CAM on. Tested all the paths when customer added a feature to the CAD drawing. I don't want to wipe out the CAM work.
How do I update the CAD file with this new feature without affecting the CAM?
I am assuming if I do a SAVE AS, with same name, it will over write everything I did.
Rob
- Just In V27 UPDATE
- Update
- IH update
- USB Update
- Update!
Oh, thank you much.
That makes sense.
Rob
Make a copy first in case something goes wrong
The merge worked for most part on a test file, except they have me A down level file with added feature. good thing I did a test file.
I added the feature myself.
Anyway the merge, solves my question.
Rob
