Need Help! Strange cutter path finish
Results 1 to 7 of 7
Thread: Strange cutter path finish
    Member Bazzer's Avatar
    Apr 2016
    United Kingdom
    Default Strange cutter path finish
    Does anyone have any ideas on what might be causing this strange finish on an aluminium tool that we are machining?
    The stepovers are .1mm so we were expecting to get a really nice finish. Machining stratergy is 'Planar', there is stock left at 0.25mm and semi rough cut of 1mm stepovers, the rough cut image is also attached.
    The 3D model seemed smooth when viewed in a number of CAD packages, the model that was imported into BobCAD is in the attached ZIP file.
    Any pointers would be gratefully received.
    Regards
    Barrie
    Attached Thumbnails Attached Thumbnails Strange cutter path finish-img_2296-jpg   Strange cutter path finish-img_2291-jpg
    Attached Files Attached Files
    Barrie @ Composite Specialities Ltd. using BobCAD V30 Mill 3 axis Pro, Bricscad V14 and MOI V3 with CNC-Step High Z 1000S and Wabeco CC-F1210
    Jun 2005
    Default Re: Strange cutter path finish
    Bazzer,
    Is that surface smooth? It looks rough and it appears your spindle is out of tram. Did the same machine do the machining on the outer rim which looks good?
    Russ
    Apr 2016
    United Kingdom
    Quote Originally Posted by CNCMAN172 View Post
    Bazzer,
    Russ
    Hello Russ
    Yes all done on the same machine which is a Dugard. The machine produces good work, lots of precision aerospace stuff and the machinist is very good.
    We have done full 3D paths before but not had this problem.
    Where I think you are suspecting out of tram is actually some wide bands where the 4mm ballnose cutter has bunched say 100 passes together and made that horrible fore and aft band, then it has moved on and done the same again.
    Baz
    Apr 2009
    Try Equal Distance for finishing
    I cannot open your file,,but also use the largest radius tool possible
    Also reduce you CAM tolerance in settings
    Apr 2016
    United Kingdom
    Quote Originally Posted by jrmach View Post
    Ok I will check these out.
    Barrie
    Ghost BurrMan's Avatar
    Dec 2008
    I wouldn't define that surface as "smooth" but I wouldn't call it terrible either.
    I think it's a numbers game and not the surface. The part is 514 whatevers with a stepover of .1 with the tolerance set at .0127... Just not enough and it is allowing those gaps.
    I set part prefs 3d tolerance and also feature tolerance to .0001 and it smoothed the toolpath. Took about 6 minutes to calc.
    I think that is very small in metric. I didn't check how low to take things to still produce a good path...
    A good think would be if deviding that 514 with .1's, you want to allow for enough calc room on the surface to not variate, or "Jump" far off....
  7. #7
    Apr 2016
    United Kingdom
    Hello BurrMan
    As is often the case you pointed me in the right direction, it was the tolerance that was wrong.
    We ran a trial cut and it seems good, going for the whole job tomorrow.
    Many Thanks
    Barrie
