| BobCad-Cam Discuss all BobCad software here. |
| Counter Bore Steps What is the proper way to program a counter bore using an end mill in V21? Everything I've tried so far just does a Rapid to the bottom and then does a spiral. My Anilam uses a Circular Pocket to do this. John |
| It seems as if you are only picking point and performing a final cut without any roughing type operations. I would make a circle. Create the spiral path for the endmill. When you pick the spiral set the correct depth and perform roughing. If you did not make the circle smaller (for a finishing cut) the diameter of the circle will be already at size but the depth will be the only 'finishing' routine. It sounds like you are cutting to final depth to start with. If you are trying to use a specific call routine your Anilam reads then you are on your own. I also have no idea as to your ratio of endmill to counterbore size or if you have counterbore within counterbore. From what I read I believe you problem is from lack of roughing depth being set. mc_n_g |
| Where do I set the correct depth? John |
| There are several ways to c-bore. Try this. 1) draw circle at part top. 2) select circle and go to menu 'Other>Pocket>Spiral 3) Now set all the parameters includiong 'mark start' and if you intend to finish afterwards then click OK. 4) On NC side select the 'Tool Depth Settings' (up/down). Set the settings there including turning on the roughing if needed. This is where the depth is also set. 5) Selct path generated on the cad side if not alread selected. The entire path can be selected if you view in isometric and hold the shift key while clicking near the start line top. 6) On the NC side select the 'cut all'. There are other ways to do this too. |
| Where is the Tool Depth Settings? In help it shows the Machine menu when you select the tool depth settings but there is no Up/Down in there... John |
| The Up/Down Button is on the CAM Side of the Software. See Pic at bottom.It looks like this: u.... d....
| I tore the menu up looking for that and it's a button on the side bar. Not the most windows compliant software I've had the pleasure of using... Thanks Again for your help John |
| YW John, How is it working for you now?
| One thing you can do as well is add the settings to a macro call. The macro can then be added to the menu. So you can set all the variables using your own window, instructions, wording, and have it tied to lets say --the auto run feature. Just some of the things Bobcad can do. But even if there a few things you may not like many of them can be modified to meet your needs. Last edited by tjones; 02-26-2007 at 01:36 PM. |
#10
| Toby it's getting better... tjones, I'll look again at the macros. I have a v18 and 19 manual to look at as well as the v21 downloaded manual. Got to program a little PLC then I'm back on BobCad like a chicken on a june bug... Thanks again for the help John |
#11
| up/down macro I made this one today between runs. Juts add it to your windows menus and you can set a keyboard shortcut to it. You can also link it to other functions. For instance have it run prior to your pocketing. These are a few ways to use scripts in Bobcad. Last edited by tjones; 02-27-2007 at 07:41 AM. |
#12
| tjones, That is cool. I had to make a mod to it to get the output format correct. Before = Arc Cw X1. Y0. Radius 0.5F1.5 After = Arc Cw X1. Y0. Radius 0.5 Feed1.5 Now I need to study it a bit to see how I can make it do a G77 output CircPoc Xn Yn Hn Zn Dn An Bn In Sn Kn Pn Where Xn = XCenter Yn = YCenter Hn = StartHgt Zn = ZDepth Dn = Diameter An = Stepover Bn = DepthCut In = RoughFeed Sn = FinStock Kn = FinFeed Pn = ? etc. Is my thinking correct that with the correct macro I can pick a point on the drawing and select CircPock and fill in some blanks and it will generate the G-Code? John |
| Parts counter | daewooevc | Daewoo/Doosan | 1 | 11-01-2006 09:38 AM |
| Parts counter | daewooevc | Mazak, Mitsubishi, Mazatrol | 1 | 10-26-2006 05:36 PM |
| Full Steps -vs- Micro Steps | DJB282000 | General Electronics Discussion | 10 | 12-29-2005 12:25 AM |
| counter | cncsdr | Haas Mills | 2 | 11-08-2005 08:56 AM |
| counter-weights | georgebarr | DIY-CNC Router Table Machines | 15 | 02-14-2004 09:56 PM |
