Originally Posted by
BurrMan
So it looks like the post is missing a variable that outputs the inverse instruction.
I added "movement_mode" variable (without the quotes) to the standard start of file and "feed_mode" to line 55 also, and your post now outputs the G93 at the start....
It IS a different post than the standard BC_4x_Mill post we use, so I cant really confirm that that is the entire change needed or if it outputs good for your machine etc.....
My suggestion would be to start with the BC_4x_Mill standard post, then modify "IT" with the changes your machine needs, referring to the OEM has post as a reference.
If you are uneasy with that, and want your post to do inverse, I would refer to the BC_4x_Mill post for the feed_mode variable and be sure it's where it needs to be. (see the other 50's lines, etc....)
But I know nothing about your machine... here is your post with just the 1 line changed to test.
[Edited and corrected variable names in text]
