Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > BobCad-Cam
BobCad-Cam Discuss all BobCad software here.
Old 02-20-2007, 11:28 PM
bhkelly is on a distinguished road
Opening dxf in bobcad
I recently purchased some vector art that came in several types(ai,dxf, several picture types)
when I open the dxf file with bobcad v20 there is nothing to view.
nothing is blanked, changed my background color, zoom in, zoom out ,nothing !!!
am I missing somthing
thanx for any help
Old 02-20-2007, 11:59 PM
tobyaxis's Avatar
Moderator
tobyaxis is on a distinguished road
Something doesn't sound right about that. Maybe the DXF File is Corrupted. DXF is the best Wire Frame Translater.
If you post a File I can take a look for you.
Toby D.
"Imagination and Memory are but one thing, but for divers considerations have divers names"
Schwarzwald
www.refractotech.com
Old 02-21-2007, 07:51 AM
The One is on a distinguished road
Maybe the dx file is comprised of Splines...This would be the most common of occurrances.
You will need to open them in AutoCAD or something similar and explode the Splines into simple entities...
Regards
Old 02-21-2007, 10:53 AM
erase42 is on a distinguished road
when you say "open with bobcad", are you actually clicking file,open, browsing and selecting the file? Ive found that double clicking a file that as been assigned to bobcad (has taken on the bobcad logo) will usually open bobcad but not actually open the file itself on screen. I know its a dumb comment but if you are used to that working in other programs it may catch you.
Lemon Curry??
Old 02-21-2007, 01:48 PM
tobyaxis's Avatar
Moderator
That is True Erase42. I forgot about that one. LOL got use to Browsing the file from the drive drop down menu.
This might actually be the problem. Good eye!!!!!!
Toby D.
Schwarzwald
Old 02-21-2007, 11:08 PM
here is my dxf
here is one of the dxf pictures. I loaded a dxf reader and it opens the file so I know the file is not corrupt. I have access to autocad but I have bobcad at home. just wondering if it is something I am doing wrong
thanx for all the input
hope you can open the file
Old 02-22-2007, 12:48 AM
tobyaxis's Avatar
Moderator
Ok, got the same results you did. Have you tried these Forums yet?
http://216.117.147.20/bobcadsupport/forums/index.php
http://cadcamtrainer.com/forums/index.php
If these guys can't help you call BCC Support on the phone. They may have an answer for you.
BTW: for now convert the file to a DWG AutoCAD File and Try that one too.
Cheers!!!!!!
Toby D.
Schwarzwald
Old 02-22-2007, 06:53 AM
Thanx for the help, and keep the shiny side up!!!!!!
Old 02-22-2007, 08:09 AM
The problem is your file is a Hatch entity. It needs to be exported as Lines and Arcs.
You will need to open the original file and export the boundary that was used to create the Hatch entity.
Regards
Opening Mastercam In Bobcad lakeside BobCad-Cam 10 05-02-2006 11:38 AM
3d STL error opening Sanghera Mastercam 6 12-26-2005 08:19 PM
Opening .dwg files in VM 5.0 jfteague Visual Mill 5 01-17-2005 09:00 AM
Picture opening method. ynneb Suggestions for the CNCzone.com site. 7 08-01-2004 01:29 AM
Thanks for opening this forum CNCadmin OneCNC 3 03-31-2003 11:31 PM
