Need Help! generating custom code
Results 1 to 4 of 4
Thread: generating custom code
    Member deadlykitten's Avatar
    Jun 2015
    Antarctica
    Default generating custom code
    hello guys please consider a lathe with live tools / multifunction machine, thus turning and milling axis : S + M
    there is a situation where code for
    one operation must be created accordingly to next operation
    for example, if operations are :
    ... S,S or M,M, thus same operations, one after another, than
    code_type_1 should be generated
    ... S,M, thus milling after turning, than code_type_2 should be generated
    ... M,S, thus milling before turning, than code_type_3should be generated
    so, is it possible to generate code in this manner ?
    also, if yes, is it possible to generate code for "last operation"
    accordingly to "1st operation" ? this is good when program is looped
    code variants are :
    ... type 1 : G00 X=contast Z=constant M203
    ... type 2 : G00 X=contast Z=constant M203 M05 M63
    ... type 3 : G00 X=contast Z=constant M203 M109
    please, answer even if not possible kindly !
    we are merely at the start of " Internet of Things / Industrial Revolution 4.0 " era : a mix of AI, plastics, human estrangement, powerful non-state actors ...
    Jun 2015
    Antarctica
    Default Re: generating custom code
    how many types of returns do you use ? ( turret to safe position after operation finished )
