J&R Machine,
On the NC Editor side of V21, go to File/Setup and you can change the extension there.
I have bobcad v21 and I need to get it to save gcode files with .eia extension rather than .cnc or .txt for use on Mazak mill. Is there a way to do this?
J&R Machine,
Thank you very much. That was almost too easy. I kind of feel stupid now but I got the info I needed Thanks again.
You wouldn't happen to know where I could get a post processor for v21 for a Mazatrol m32. My post processor cd is damaged and no longer works and bobcad doesn't support. v21 anymore. I should probably upgrade but v21 just seems so simple compared to newer versions. I altered a fanuc postprocessor and got the Mazak to accept code through the tape port but I still cant get it to store a gcode program. Ive been told it needs the .eia extension in order to do this.
I think I still have my V21 PP CD somewhere in the stores, I`ll see if I can find it next time I am at that location which I think will be Wednesday (I rotate around 3 locations )
Regards
Rob
:rainfro: :rainfro: :rainfro:
J&R,
I will PM you a download link to download the 2 post processors we have for Mazak M32 for V21.
