Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > BobCad-Cam
BobCad-Cam Discuss all BobCad software here.
Old 02-17-2007, 11:10 PM
Dfennell is on a distinguished road
BobArt help
What's the best method for machining this path emboss in Bobart? It's aprox 5in X 2.5in... V cutter? I'm having trouble with the setup inside of Bobare specifically. Anyone have experience using it? How would you set this up to mahcine on a .25 X 6 X 3 in part for example? I'm just about ready to eat the pages of the bobart manual to get some more substance from them :-)
Zipped file to get it to fit on the post -
Old 02-18-2007, 01:19 PM
tobyaxis's Avatar
Moderator
tobyaxis is on a distinguished road
Have you posted here http://cadcamtrainer.com/forums/index.php and here http://216.117.147.20/bobcadsupport/forums/index.php too?
I bought BobArt ProX to play with but haven't done that much with it. Try posting in those forums and someone will be able to help you. Actually most of those members are here too but it is best to post you question everywhere.
Is this what you want? Follow this link http://cadcamtrainer.com/forums/show...3&postcount=58
The Zip I saved wouldn't upload here so I put it on Sorin Nenu's Forum CAD/CAM Trainer. I think your a member already but if you aren't, just register . Your file is waiting for you. I hope you have a fast internet connection because the zip is 3.16MB.
Don't understand why it wouldn't load here.
Name:	Iron Maiden Eddy.jpg‎
ID:	31997   Click image for larger version
Name:	failed upload.JPG‎
Toby D.
"Imagination and Memory are but one thing, but for divers considerations have divers names"
Schwarzwald
www.refractotech.com
Old 02-18-2007, 11:39 PM
Thanx Tpby, I'll go log on over there and check it out ( and make a post). The Bobart portion of the the program has been a bit tricky.
Old 02-19-2007, 07:34 AM
tobyaxis's Avatar
Moderator
Yes it is. I really never use it but sure someone out there does that can really help you a lot.
Toby D.
Schwarzwald
Old 01-06-2011, 12:50 PM
ErnieD is on a distinguished road
Bobart
I am having great difficulty with Bobart. I am running v24 and trying to go from a photograph to a toolpath. Nothing that I do seems to work. I am familiar
with BC but Bobart just does not work for me.
I have the video series on Bobart but they do not show anything being done with a photograph. Is there something available, that I have not found, that will show me how to go from a PHOTOGRAPH ( I am not shouting, just emphasizing )to a toolpath?
Thanks,
Ernie
Old 01-06-2011, 01:37 PM
BurrMan is on a distinguished road
Here is an example at the simplist level.
YouTube - simple bobart
This is V23 but i dont think anything has changed..
The yellow surface created you can think of like a regular surface...(Just cant do geometry operations on it, like cutting and such)
Toolpath it with something like a slice planar...
BobArt pro x bbergami BobCad-Cam 2 06-03-2006 11:53 PM
Can Bobart be run without zonker BobCad-Cam 6 01-03-2006 10:03 PM
Bobart Pro X Randall BobCad-Cam 0 08-16-2005 12:33 PM
Bobart pro X? fastolds BobCad-Cam 12 06-27-2005 10:51 AM
BobART 2D CNCdude BobCad-Cam 0 07-27-2004 10:06 AM
