Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > BobCad-Cam
BobCad-Cam Discuss all BobCad software here.
Old 02-16-2007, 11:47 AM
jayou is on a distinguished road
Question Can I upload data from milling machine to BobCAD??
I type my program into my milling machine by front panel.
Can I upload these data from milling machine to BobCAD??
I want to save these data on my PC.
Anyone can help me??
Old 02-21-2007, 07:45 AM
The One is on a distinguished road
Yes you can. You will need to set BobCAD up to receive. Then snd the file from the machine.
For more specifics you will need to make sure that BobCAD jives wuth the settings on your machine. That is, make sure that your Baud Rate, Data Bits, Parity and Stop Bits are set the same between the machine and the computer. You may need to adjust the settings on the computer to get all of the data, but it can be done.
Regards
Running BobCad/Cam and Mach 3 on the same machine? Corvus corax BobCad-Cam 9 01-11-2007 10:19 PM
need help with tos milling machine derkiow General Metal Working Machines 0 03-08-2006 09:06 AM
Excello Software Upload on IBH machine ChopperDoc Mazak, Mitsubishi, Mazatrol 3 06-21-2005 03:51 PM
Why would this machine be bad for milling? jevs Knee Vertical Mills 5 06-16-2005 11:49 PM
D&M Milling machine mrand Benchtop Machines 1 03-11-2005 03:58 AM
