Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > BobCad-Cam
BobCad-Cam Discuss all BobCad software here.
Old 01-28-2007, 06:35 PM
youngfg is on a distinguished road
Solids interior lines settings
When I upgraded to ver 20.7 now when I create a solid of a surface the interior line settings are zero, and brightness of zero. I have to change them in the attributes to be able to see them. How can I set the default settings for the interior lines?
Old 01-28-2007, 06:39 PM
tobyaxis's Avatar
Moderator
tobyaxis is on a distinguished road
Go to the Attributes Settings with nothing selected. Solids Tab Change your Color, Interior Lines, & Brightness. Click OK and your done.
Name:	attributes solid color changing.JPG‎
Toby D.
"Imagination and Memory are but one thing, but for divers considerations have divers names"
Schwarzwald
www.refractotech.com
Old 01-28-2007, 09:23 PM
erase42 is on a distinguished road
Hi guys, I think what the underlying question is, how do we get it to STAY that way. I know that I have to go in and set my preferences all the time. I havent noticed if i have to do it every time, but i know for a fact that ive gone and set grid and snap point settings all the time. Ive also noticed that in v21, i cannot get the grid to come on. Ive set it, activated it and still nothing. I went to colors to see if maybe the grid was set to white dots, and there is no color swatch there for the grid, just a beige area. any ideas?
Lemon Curry??
Old 01-29-2007, 07:37 AM
The One is on a distinguished road
What you both have to do is open BobCAD to a blank drawing space. Set everything up the way you want it. Use File -> Exit to colse the file. When you open the program again, provided you have write permissions to the registry keys, the settings will be the same as when you closed it.
Regards
Old 01-29-2007, 10:03 PM
tobyaxis's Avatar
Moderator
Have nothing selected when you open the Attributes Dialog Box. It will default to those settlings after you save the Drawing.
Also like what The One Said
Toby D.
Schwarzwald
Old 01-29-2007, 10:12 PM
any ideas on my not being able to get a grid to show up? I think its there because it creates snap points, but i cant see it. in color settings there is no color shown to change just the beige background of the dialog box. it works in my newer v21 so i know im not just too dumb to set it.
Lemon Curry??
Old 01-29-2007, 10:20 PM
tobyaxis's Avatar
Moderator
NoBody is DUMB Buddy!!!
I don't use it but I'll take a look.
Toby D.
Schwarzwald
Old 01-29-2007, 10:24 PM
tobyaxis's Avatar
Moderator
Ok
File>Envirionment>Grid>Activate Check Box> Set the spacing the way you want>Ok.
Next
File>Envirionment>Colors>Select Grid>Modify>chose a Color>OK
That should do it
Toby D.
Schwarzwald
Old 01-30-2007, 01:30 PM
there is something glitchy there with the grid. cuz it worked fine today, sort of. you still cant change the grid color. there is simply no color next to grid to change like the items on the list above "grid"
it shows up in red on the screen anyway which is fine. I wonder if having files created in v 19 open on the system were preventing me from changing grid settings?
Lemon Curry??
Old 01-30-2007, 06:13 PM
tobyaxis's Avatar
Moderator
I don't see that affecting anything but it might be a good idea to give Tech Support a Call.
Toby D.
Schwarzwald
Making interior doors WarrenW WoodWorking 10 04-08-2008 07:34 PM
Looking for a supplier of interior splined shaft JerryFlyGuy Mechanical Calculations/Engineering Design 2 06-09-2006 03:29 PM
Help With Solids helix77 General CAM Discussion 2 01-05-2005 12:51 PM
How do I create solids from lines? HawainPand BobCad-Cam 2 09-12-2004 01:36 AM
solids tsutt Mastercam 3 04-06-2004 10:33 PM
