Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > BobCad-Cam
BobCad-Cam Discuss all BobCad software here.
Old 01-21-2007, 09:25 PM
jpcuttergrinder is on a distinguished road
help with bobcad on a hurco kmb1
I have recently purchased a Hurco kmb1 mill. I have used it a little using the hurco conversational programming but now I am trying to program it using bobcad 21.
I am trying to mill out the profile of a rocker arm for a pulling tractor. I tried using the post processor that was supplied by Bobcad and the machine won't even take the program because it has to have a % sign at the start of the program.
I have contacted the previous owner of the mill and he used to program it with bobcad v 20. He helped me a little but something is still not right.
I am milling the rocker in 4 passes each at .250 deep at an offset of .280 using a .500 cutter. This gives me a .030 finish pass.
My main problem is that the cutter will plunge to -.250 and start milling but on arcs it ramps up to 0 by the time it gets to the start of the next arc when I want it to stay at -.250 and cut all the way around the part. Also when I get to milling out the 1" hole in the center of the rocker, the mill stops and says "bad arc DB" . I don't know if the problem is in the way I draw the part or just the way post processor is producing the g-code? By the way, the simulation in bobcad seems to work just fine.
Any help would be appreciated.
Here is my program
N 2%
N 4G00
N 6G90
N 8G70
N10M25
N12S2500 M3
N42Z0.5
N44X0.418Y0.05Z0.5
N46G01Z-0.25F5.
N48X1.1102Z-0.25F10.
N50G02X1.1171Y0.0488Z-0.25I1.1102J0.03K-0.25
N52G03X4.3262Y0.1998Z-0.25I2.5438J3.9015K-0.25
N54X3.9236Y1.4342Z-0.25I4.042J0.79K-0.25
N56G02X2.9587Y1.8745Z-0.25I3.7563J2.3449K-0.25
N58G03X0.7763Y1.6998Z-0.25I1.91J1.256K-0.25
N60G02X0.4485Y1.491Z-0.25I0.4694J1.8199K-0.25
N62G03X-0.062Y1.012Z-0.25I0.418J1.012K-0.25
N64G01Y0.53Z-0.25
N66G03X0.418Y0.05Z-0.25I0.418J0.53K-0.25
N68G01Z-0.5F5.
N70X1.1102Z-0.5F10.
N72G02X1.1171Y0.0488Z-0.5I1.1102J0.03K-0.5
N74G03X4.3262Y0.1998Z-0.5I2.5438J3.9015K-0.5
N76X3.9236Y1.4342Z-0.5I4.042J0.79K-0.5
N78G02X2.9587Y1.8745Z-0.5I3.7563J2.3449K-0.5
N80G03X0.7763Y1.6998Z-0.5I1.91J1.256K-0.5
N82G02X0.4485Y1.491Z-0.5I0.4694J1.8199K-0.5
N84G03X-0.062Y1.012Z-0.5I0.418J1.012K-0.5
N86G01Y0.53Z-0.5
N88G03X0.418Y0.05Z-0.5I0.418J0.53K-0.5
N90G01Z-0.75F5.
N92X1.1102Z-0.75F10.
N94G02X1.1171Y0.0488Z-0.75I1.1102J0.03K-0.75
N96G03X4.3262Y0.1998Z-0.75I2.5438J3.9015K-0.75
N98X3.9236Y1.4342Z-0.75I4.042J0.79K-0.75
N100G02X2.9587Y1.8745Z-0.75I3.7563J2.3449K-0.75
N102G03X0.7763Y1.6998Z-0.75I1.91J1.256K-0.75
N104G02X0.4485Y1.491Z-0.75I0.4694J1.8199K-0.75
N106G03X-0.062Y1.012Z-0.75I0.418J1.012K-0.75
N108G01Y0.53Z-0.75
N110G03X0.418Y0.05Z-0.75I0.418J0.53K-0.75
N112G01Z-1.F5.
N114X1.1102Z-1.F10.
N116G02X1.1171Y0.0488Z-1.I1.1102J0.03K-1.
N118G03X4.3262Y0.1998Z-1.I2.5438J3.9015K-1.
N120X3.9236Y1.4342Z-1.I4.042J0.79K-1.
N122G02X2.9587Y1.8745Z-1.I3.7563J2.3449K-1.
N124G03X0.7763Y1.6998Z-1.I1.91J1.256K-1.
N126G02X0.4485Y1.491Z-1.I0.4694J1.8199K-1.
N128G03X-0.062Y1.012Z-1.I0.418J1.012K-1.
N130G01Y0.53Z-1.
N132G03X0.418Y0.05Z-1.I0.418J0.53K-1.
N134G00Z0.5
N226X2.13Y1.256Z0.5
N228G01Z-0.25F5.
N230G03Z-0.25I1.91J1.256K-0.25F10.
N232G01Z-0.5F5.
N234G03Z-0.5I1.91J1.256K-0.5F10.
N236G01Z-0.75F5.
N238G03Z-0.75I1.91J1.256K-0.75F10.
N240G01Z-1.F5.
N242G03Z-1.I1.91J1.256K-1.F10.
N244G00Z0.5
N266X0.418Y0.05Z0.5
N268G01Z-1.F5.
N270X1.1102Z-1.F10.
N272G02X1.1171Y0.0488Z-1.I1.1102J0.03K-1.
N274G03X4.3262Y0.1998Z-1.I2.5438J3.9015K-1.
N276X3.9236Y1.4342Z-1.I4.042J0.79K-1.
N278G02X2.9587Y1.8745Z-1.I3.7563J2.3449K-1.
N280G03X0.7763Y1.6998Z-1.I1.91J1.256K-1.
N282G02X0.4485Y1.491Z-1.I0.4694J1.8199K-1.
N284G03X-0.062Y1.012Z-1.I0.418J1.012K-1.
N286G01Y0.53Z-1.
N288G03X0.418Y0.05Z-1.I0.418J0.53K-1.
N290G00Z0.5
N292X2.16Y1.256Z0.5
N294G01Z-1.F5.
N296G03Z-1.I1.91J1.256K-1.F10.
N298G00Z0.5
N300M05
N302M25
N304M02
N306%
Old 01-24-2007, 10:35 PM
tobyaxis's Avatar
Moderator
tobyaxis is on a distinguished road
If the previous owner used BCC to program this machine you can Copy his Post Processor into your BCC files and use it.
This might help you to produce good G-Code for your Mill.
Toby D.
"Imagination and Memory are but one thing, but for divers considerations have divers names"
Schwarzwald
www.refractotech.com
Hurco KMB1 question jpcuttergrinder General CNC (Mill and Lathe) Control Software (NC) 13 11-02-2006 05:39 PM
Hurco KMB1 with bx upgrade jpcuttergrinder General CNC (Mill and Lathe) Control Software (NC) 1 10-14-2006 11:38 PM
Hurco kmb1 BTR ??? drill General CNC (Mill and Lathe) Control Software (NC) 0 01-10-2006 12:42 PM
Hurco kmb1 help!!! drill General CNC (Mill and Lathe) Control Software (NC) 1 01-03-2006 12:40 AM
