Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > BobCad-Cam
BobCad-Cam Discuss all BobCad software here.
Old 01-17-2007, 12:59 PM
PillyWilly is on a distinguished road
Not even close ?
Hey
I have DL the trial version of BOBcad-cam v.21 and 3 different postprocessors for Biesse machines (I'm using al 1998 Biesse 13 S NC 400+) but the code produced by Bobcad is not even close to the .PAN files that is saved from the NC, will it run anyway ?
I have attached a file as it is direct from the mashine, only renamed it from .pan to .txt. (open with ex Write)
it is a square 500x500 mm with R25 on all corners
I hope somone can help me out, because I really want to use the software, but cant get my boss to spend the money, if i is not working properly
I´m sorry for my crappy english (Dane)
Thnx
Jan
Old 01-17-2007, 05:30 PM
The One is on a distinguished road
It can be done, but the existing post needs tweaked.
You should contact BobCAD and let them know that you are thinking of buying but need the post before hand.
They should be able to work with you on this, but it may take a week or two time to get the post 100%.
Regards
