Here's a link to a dxf file of mine:
http://www.hermandesign.us/cad/CAMLineOrder.nc
Simply change the nc to dxf after downloading. It stops it from just showing the text of the dxf file in the browser window.
This is just a part of a huge file like this. When I refresh the larger file in AutoCAD or BobCad you can see that it does every other line and then the in betweens as it refreshes. Is there a way to renumber or reorder the lines in the file? Because when I machine the file, through BobCad's Generate NC menu option, it does two passes: Odd then even or vice versa. My desired .0625" stepover becomes a staggered .125" stepover and due to the greater cut width and tool flex, the finish does not come out the same. Thanks.
Rob
